Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 01-19-2006, 04:33 PM   #1
Philip Williams
Profile:
Question Shower faucet
1988 Excella, the shower faucet has low pressure, like no hot water abd it leaks where the showe hose connects. I was thinking about replacing this entire fixture wuth a faucet that has the hose connection coming out of the top of the fixture. Has any one done this or does anyone have a suggestion?
Philip Williams is offline   Reply With Quote
Old 01-19-2006, 04:51 PM   #2
BigAl
Profile:  1994 30' Excella
Mississauga , Ontario
I have a 94 and it also has low pressure and minimal water flow. That is probably to conserve water and not fill grey tank too fast. As for the leak at the hose connection it is probably a back flow preventer and it should leak after you turn off the water but not while using the shower.
they are designed to prevent dirty water from gettting sucked back into your drinking water supply..
Al
Old 01-19-2006, 04:59 PM   #3
Philip Williams
Profile:
Appreciate your reply. I thought of the points you mentined but I mean LOW water pressure! Also it leaks at the connection even when water is on. ??
Old 01-19-2006, 06:07 PM   #4
Janet
Janet's Avatar
Profile:  Eastern , Washington
Images: 63
Way out of my league... but you may have an inline filter somewhere that is plugged. Our trailer has one just uphill from the city water intake...
77 Argosy Minuet, 6 metre
77 Argosy 24, Rear door
AIR 3181, WBCCI/VAC # 5575
Wally for President
Janet is offline   Reply With Quote
Old 01-19-2006, 07:20 PM   #5
john92021
Profile:  1972 20' Argosy 20
Alpine , California
Hi, Be sure to screw the shower head off and clean the filter in there. I almost tore the thing apart before I checked the obvious one.
John
john92021 is offline   Reply With Quote
Old 01-19-2006, 07:49 PM   #6
j54mark
Profile:
As noted above, clogged outlets in the shower head will cause exactly the symptoms you mention - both the low flow rate and the leak at the hose connection. You may also have small bits of debris in the faucet itself, which would cause the low flow rate, but not the leak at the hose connection. That could be a simple washer replacement.
Good luck,
Mark
'85 Sovereign, 25'
Old 01-23-2006, 10:53 AM   #7
Philip Williams
Profile:
I will dig deeper, thank you.
Old 01-24-2006, 03:21 AM   #8
Buttercup
VAC Membership Chair
Buttercup's Avatar
Profile:  1977 27' Overlander
1954 25' Cruiser
VC Highlands , Nevada
We replaced our shower valve because it had froze and came apart in about a dozen places.
We documented the steps we took. Your experience may be different but the one thing that doesn't change - you can do it if you need to and the good thing is that you can put in a real nice unit to replace the old one.
Don't let the IBT Scuttle the WBCCI - Just Vote NO! Save Wally! Buttercup Web site Looking for a unit? Check out the SaveWally Unit Guide.
WBCCI # 17330, VAC Membership Chair, CAC Member
2008 Mouse count:
Buttercup -
Airtini -
Buttercup is offline   Reply With Quote
Old 04-10-2006, 01:23 PM   #9
Condoluminum
Condoluminum's Avatar
Profile:  1988 25' Excella
Sunnyvale , California
Try adjusting or replacing cartridge?
Philip-
May be too late, but I wondered if you had owner's manual for your Excella including detailed section on adjusting the cartridge for flow in your shower mix valve? We've had lingering issues with ours as well, dripping on hot side...
Valve was made by company called NIBCO (not Moen) and cartridge included a pair of adjustible plugs inside. Process requires a long and very fine (5/64") allen wrench to turn the plugs at the back and adjust flow and stopping points.. If you do not have manual describing process, let me know and I'll scan ours and send via PM. Manual also describes removal process for cartridge to check it.
If failed, NIBCO sold the business to Phoenix Products in Avon Lake (Cleveland area) Ohio in 1995. They still make some of the parts available for both shower mix valves and sink faucets. They can be reached at (800) 222-6041, or on the web. By the time you look at 90 degree inlets and number of piping changes to make, fixing existing valve might be easier than total replacement...
John McG
>> Proving the falsity daily to the song "It never rains in California..."
Condoluminum
Condoluminum is offline   Reply With Quote
Old 02-08-2007, 06:32 PM   #10
rmscottrds
Newburgh , New York
On you water hook-up, is there a pressure reducer? We had a leak at the shower head and went to a campground that had these at all the sites. We had no leak after that. We also bought a reducer at Walmart just in case subsequent campgrounds did not.
rmscottrds is offline   Reply With Quote
Old 02-09-2007, 05:22 PM   #11
Condoluminum
Ours leaked and dribbled even with pressure regulator...
We did find sources for NIBCO replacement cartridges. Lowe's shows them in their catalog, though they aren't stocked at stores. Our new store couldn't exactly figure out how to order one from their own catalog, but their supplier took pity and furnished the replacement cartridge directly to us...
Search on NIBCO to find current suplier and model number. Price around $14. New springs, seats and body will solve flow and shutoff issues, and a lot easier than changing the entire valve, which has four threaded pipe connections (brass and plastic) in tight space against flat surface...
Condoluminum
Old 02-09-2007, 07:55 PM   #12
alan
Profile:
Shower faucet
Be careful on this one.
I found water dripping on the backside of the shower wall. Turns out that the original shower faucet was installed upside down (I wondered why cold water was on the left).
The shower faucet should be installed with the shower connection down. When shut off, the water in the line to the shower head drains back into the valve body, and then out the bottom. In my case, the water was collecting in the body of the shower faucet, and then finding its way through the wall.
1985 25' Sovereign
Corner Bed
2003 3/4 ton Suburban
6.0, 3.73
Bellingham, WA
alan is offline   Reply With Quote
1985 Excella shower vent fan gimmejul Roof Vents, Skylights & Fans 8 05-01-2003 08:56 PM
First shower in my 1975 Overlander !!! pjtaia Our Community 13 10-30-2002 08:52 AM
Shower head problems Pahaska Our Community 25 08-26-2002 11:43 AM
Shower head Pahaska 2003 International 0 08-24-2002 05:13 PM
Shower head Pahaska 2003 International CCD 0 08-24-2002 05:12 PM
