Old 11-09-2018, 07:46 PM   #1
Julie-Bob's Avatar
2009 25' FB Classic
Scottsdale , Arizona
Shower drain Replacement
My 2009 25’FB Classic shower drain has corroded and needs replacing. How does one get to the nut under the shower pan to loosen the nut??
Bob & Julie # 5587, 4CU in AZ
Julie-Bob is offline   Reply With Quote
Old 11-09-2018, 08:11 PM   #2
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
On mine there is an access plate in the belly pan that allows you to get to the p-trap and shower drain.
Old 11-10-2018, 01:11 PM   #3
Julie-Bob's Avatar
2009 25' FB Classic
does the shower drain just unscrew from the drain pipe under the shower?? I have looked under the trailer and the pan covers the area under the shower. Has anyone removed this shower drain pipe??
Old 11-10-2018, 02:55 PM   #4
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
I have a 2008 Classic 25fb. If you remove the furnace duct and have small hands you can access the shower drain. Other wise you will need to remove the wall. I was able to get my hand in there with a small adjustable wrench to loosen mine to fix a leak.
Kelvin
Old 11-10-2018, 07:08 PM   #5
Julie-Bob's Avatar
2009 25' FB Classic
Thanks. I will check it out.
Re working kitchen drain- pex for drain lines?? bwilson1 General Repair Forum 4 04-20-2014 08:42 PM
Shower drain replacement Del Gurney Sinks, Showers & Toilets 4 12-29-2012 04:24 PM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 04:09 PM
Shower Drain Dbraw Sinks, Showers & Toilets 1 03-12-2003 10:59 PM
Shower drain plug Zed2 Sinks, Showers & Toilets 1 01-04-2003 05:33 PM
