Old 12-05-2002, 08:18 AM   #1
Zed2's Avatar
2007 25' Safari FB SE
Plano , Texas
Shower drain plug
My family has finally decided to start using the shower in our 1965 Caravel. The drain plug that is in the basin has not been removed in many years and I am fearful that when I pry it out of the drain it will disintegrate. Therefore, I would like to obtain a replacement. Does anyone have a source for a replacement or specifications of the original drain plug?
Keith
Zed2 is offline   Reply With Quote
Old 01-04-2003, 05:33 PM   #2
JLD
Send a message via AIM to JLD
Hi. I suggest you lubricate it liberally with silicone spray before trying to remove it. The other thing I would try is drilling a quarter inch hole in the center where the original ring for the plug was and then gradually widening it. Good luck .
JLD is offline   Reply With Quote
Fresh water drain plug sticks skipj Fresh Water Systems 16 11-06-2009 06:43 PM
Shelf Doors/ Shower Curtain question srgntpepper 1960 - 1965 Safari 5 01-06-2004 05:03 PM
Ugh! shower leak detected. mcostanzo Sinks, Showers & Toilets 1 10-03-2003 10:33 AM
Sagging Shower w9det 2000 - 2004 Safari 1 09-12-2003 01:28 PM
Shower Drain Dbraw Sinks, Showers & Toilets 1 03-12-2003 10:59 PM
