Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 08-09-2007, 09:51 AM   #1
Moonstruck
Commercial Vendor
Moonstruck's Avatar
Profile:  1986 31' Sovereign
Sherfield English , Hampshire
Shower Drain Corroded
Hi Guys, the newbie vendor soldiers on! Lol!
thought you might be able to advise with a problem I have on both my Airstreams. The (I'm sure it's) aluminium shower waste is rather badly corroded. The "metal" is oxidising and as a result the waste is blocking and taking an age to drain. I would like to replace both with plastic or brass fittings. What is the simplest access point to the underside of the shower tray. I'm anticipating drilling out some rivets and removing a belly panel - is this the case?
Regards,
Marc
www.silvertwinkie.co.uk
Moonstruck is offline   Reply With Quote
Old 08-09-2007, 11:03 AM   #2
blondie3265
blondie3265's Avatar
Profile:  1975 Argosy 22 Rear Door
Vian , Oklahoma
Yes we just did this last weekend. Sounds like your drain is a twin to this one. Hubbie couldn't get the drain to come out . So he had to remove rivets and belly pan to get to it. It wasn't to bad a loss, going to have to replace some of the underbelly anyway.
blondie3265 is offline   Reply With Quote
Old 08-13-2007, 03:33 AM   #3
Moonstruck
Commercial Vendor
Moonstruck's Avatar
Thank you blondie!
As I said I have to do it on both so I'll start on my Excella(not inhabited) and learn all the lessons there before fixing the Sovereign.
Regards,
Marc
1985 Excella shower vent fan gimmejul Roof Vents, Skylights & Fans 8 05-01-2003 08:56 PM
Shower drain plug Zed2 Sinks, Showers & Toilets 1 01-04-2003 06:33 PM
low drain points Raptorrider2001 1999 Safari 18 12-12-2002 05:17 PM
Shower stall walls 53flyingcloud Upholstery, Blinds, Walls & Interior Finishes 7 08-31-2002 12:38 PM
Removing the shower stall - 61 Bambi 61BambiCanada Upholstery, Blinds, Walls & Interior Finishes 8 06-16-2002 11:35 AM
