Old 03-12-2003, 12:36 PM   #1
Shower Drain
While repairing the floor in the bath area of our 1971 Safari, I had to remove the shower pan strainer. I had to cut it into to get it out. Then started looking for a replacement. After checking several RV catalogs and plumbing supply houses without any sucess, I went to Lowes and believe it or not, found a brand new one just like the original. Solid brass and chrome plated. It cost about $11.00. It is called a Bar Strainer and is distributed by LG Sourcing, Inc. N. Wilkesboro, NC. I thought I would share this info with the Forum in case someone else has the same need. I continue to be impressed with the quality of parts that were used in the original Airstreams.
Dan
Dbraw is offline   Reply With Quote
Old 03-12-2003, 10:59 PM   #2
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Good post Dan and thanks for sharing your discovery with the members.
-BobbyW
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Shelf Doors/ Shower Curtain question srgntpepper 1963 Safari 5 01-06-2004 05:03 PM
Ugh! shower leak detected. mcostanzo Sinks, Showers & Toilets 1 10-03-2003 10:33 AM
Sagging Shower w9det 2001 Safari 1 09-12-2003 01:28 PM
Shower "door" leak mcostanzo Airstream Motorhome Forums 1 08-11-2003 09:37 AM
Shower drain plug Zed2 Sinks, Showers & Toilets 1 01-04-2003 05:33 PM
