Old 02-22-2016, 12:53 PM   #1
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
Shower drain
I am curious to know what others use to clean the drain in the shower?
Thank
urnmor is offline   Reply With Quote
Old 02-22-2016, 01:35 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Get an old rubber bath tub stopper and drill a 3/8 or so hole through it. Put it in the drain and push a garden hose to it while the hose is turned on.
That is an old shore trick for the sand you track into the shower.
The drain is just a trap so it should not hold anything link hair the way a sink drain does.
2004 Excursion 4x4
Old 07-03-2016, 12:59 PM   #3
Yertle01.com
TRizzuti's Avatar
2006 22' International CCD
Estes Park , Colorado
I take a metal coat hanger, straighten it out, then bend a very small hook on one end. Fish it down the drain to the trap, twirl it and pull it out. Repeat. Nasty job, but you can pull most of the hair out this way. Works at home, too.
Terry P. Rizzuti, "Yertle"
TRizzuti.com
Yertle01.com
"My two cents is worth every penny."
TRizzuti is offline   Reply With Quote
Re working kitchen drain- pex for drain lines?? Bwilson11 General Repair Forum 4 04-20-2014 08:42 PM
Shower drain seal Safari Tim Waste Systems, Tanks & Totes 6 08-15-2004 11:18 PM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 04:09 PM
Shower Drain Dbraw Sinks, Showers & Toilets 1 03-12-2003 10:59 PM
Shower drain plug Zed2 Sinks, Showers & Toilets 1 01-04-2003 05:33 PM
