[QUOTE=polarlyse;1709040]Reviving this old inquiry because I have the same problem and am having NO luck finding a solution yet. Airstream tells me they no longer have a supplier for this part and can offer NO alternative. Checked around some of the parts suppliers and no luck there either. SO, Larry, did you have any luck ????? So as of now I use a small spring clamp at the top to hold the door closed for travel. Stationary, it doesn't matter the magnetic catch holds it secure.
Hope someone out there in Airstream land has some idea. If not I think I can fiddle with the broken original one and make
something that will work.
Thanks all, see ya on the road sometime.[/
QUOTE]
Yes! I bought two of them from Out of Doors Mart. Apparently they have someone who is making them. If they still have them, I would advise buying two, so you have a spare.
Larry
