My Airstream doesn't have a shower curtain or door at this time. I'm curious what others are doing for this. I noticed Sneakinup put up a curtain with a track mounted on the ceiling but I'm not sure I want to go this route.
__________________ 2003 Ford Excursion (6.0L PSD) Prodigy / Equal-i-zer / Honda EU2000i / Xantrex Link 10 U.S. Navy (Retired) Airstream Life Contributor Air#5661 / WBCCI#--
I'm going to assume you've got a rear bath. I can't give any advice on the center bath. If so:
I would second Abe's suggestion that a curtain is a better arrangement. We have the original door on our '72 and it doesn't work very well at keeping the water in the shower. On our '78 the door was missing so we replaced it with a shower curtain. It attaches to the ceiling via a rod.
On our '78 we have 3 extra hooks stuck onto the plastic around the front of the shower. We unhitch the shower curtain hangers from the rod and attach them to the appropriately spaced hooks. That keeps water from splashing out onto the sink area. Again, the '78 has a little different arrangement than the '72, but you could do the same sort of thing.
My shower curtain track is mounted to the upper cabinetry. I didn't want to drill in to the ceiling since it was in such good condition. I used the bottom track from the front window curtains to fashion a track for the shower curtain hooks. It works pretty well.
1972 27' Overlander 72 Overlander Jack Pad--- A notebook used by Jack Nicholson in the Shining to keep track of how much work he had done on his Airstream. "All work and no polishing makes Jack's Airstream a dull trailer"
to stay suspended around the bend? I see where you attached the ends but keeping it up in the middle has me stumped.
Mike
We went with a curtain also. I used a tension shower rod and it works great. They have three different lengths at wal-mart. One end is on the rear tub wall and the other over the mirror at the front of the tub.
