Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 06-26-2010, 02:56 PM   #21
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Originally Posted by howco View Post
mellomike
very nice job........
Thanks, Howco
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
https://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-08-2010, 06:10 PM   #22
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
Originally, I wanted my minimalist bathroom to have no shower curtain spoiling the lines or chopping up the space in the "contemporized" ARGOSY
But that proved unrealistic. There will always be some splash and overspray on the floor that way.
When I stumbled upon a stainless steel wire device meant for hanging fabric curtains at IKEA, I sensed I might have something that could work with the unique curves of the Airstream.
The secret is that the wire holders swivel and bend up to 180 degrees.
One end is affixed to the curved ceiling/wall and bends down; the other end runs straight out from the partition wall. The wire is tensioned from this end.
Then I went to Tractor Supply Company and bought some nickel-plated swiveling chain hooks.
An inexpensive plain white EVA curtain, found at my small town hardware and folded in half works perfectly.
After use, the curtain compacts neatly against the wall and doesn’t take up space.
Sergei
SmokelessJoe is offline   Reply With Quote
Old 07-22-2015, 05:18 PM   #23
Mission , Texas
*bump*
Our 75 Overlander rear bath came to us with no shower door or provisions for a curtain.
I like the solution pictured in post #11, but it doesn't show anchoring on the wall side.
I was thinking a 10' piece of 1/2" conduit bent into a large "O" and suspended with towel bar ends drilled out to accept the conduit. The beautification engineer suggested PVC.
What have others done? Pictures greatly appreciated!
nrgtrakr is offline   Reply With Quote
Old 01-21-2016, 02:47 PM   #24
1973 25' Tradewind
Fort Collins , Colorado
Attachment 106489
Attachment 106490
Attachment 106491
Attachment 106492
Attachment 106493
Sergei
Your idea is genius, SmokelessJoe. I have been looking for ideas to make an l-shaped rod and I think this might be the ticket if I add an additional support/fixture in between the two. Do you think that would work? Would I be able to make a 90 degree angle using this idea?
yoopersafari is offline   Reply With Quote
Old 01-21-2016, 10:19 PM   #25
1976 Argosy 24
Did you mean L. ?
If so I suppose you could work it out.
The trick would be finding the devices. Does IKEA still carry them? That was along time ago.
Like me, you will need ingenuity.
Sergei
Sergei
Old 02-02-2016, 05:48 PM   #26
1973 31' Sovereign
1958 22' Flying Cloud
San Angelo , Texas
Want to replace the folding shower door in rear bath '73 and like the devices from IKEA that SmokelessJoe used. Checked website and they still carry them. Also am tossing around the idea of mounting a retractable clothesline to hold the shower curtain, with an extra end receptacle mounted to the side. That way there wouldn't be a permanent line/rod across the tub for my tall husband to run into . Anyone tried this?
Joy M is offline   Reply With Quote
Old 04-02-2017, 09:10 PM   #27
HotelCaliGal
Driftin Di's Avatar
1991 35' Airstream 350
portola valley , California
Thank you for posting all of these parts as I have the same issue in my 1958 Flying Cloud 22'. And this I hope will work in ours. The cool thing is that if you use this rig you can use whatever fabric as the theme to match the bathroom or rest of trailer if you just get a clear PVC shower curtain to keep the water contained. Great parts and pictures! Thanks so much. PS all parts are now on Amazon.
Driftin Di is offline   Reply With Quote
Old 10-02-2022, 06:12 PM   #28
2007 30' Classic S/O
Lewisburg , West Virginia
Originally Posted by mello mike View Post
Hi David,
I bought everything here:
RECMAR 4108 Bendable I Beam Curtain Track - 8 Feet - Curtain Tracks
1 8ft track (RECMAR 4108)
2 packs of wheel carriers with shackles (RECMAR 4121)
1 pack of ceiling brackets (RECMAR 4126)
1 pack of track ends (RECMAR 4132) I used these to keep the one single mount at the bottom of the U from moving to the left or right.
My blog had additional pics and details.
If you don’t mind. How do I find your blog? I would love to see more pictures of how you did your shower.
Mntmama is offline   Reply With Quote
Shower door. Has anyone put one on a 1987 345 or similar airstream with curtain? MacInDaBox Airstream Motorhome Forums 2 05-17-2007 12:06 PM
Blinds for my 1964 Safari Neenm Upholstery, Blinds, Walls & Interior Finishes 19 09-18-2003 04:33 PM
Shower head problems Pahaska Our Community 25 08-26-2002 10:43 AM
shower curtain "cap like" grommets Neenm Upholstery, Blinds, Walls & Interior Finishes 0 08-03-2002 02:04 PM
Shower curtain Zed2 Upholstery, Blinds, Walls & Interior Finishes 1 06-24-2002 09:03 PM
