Old 07-10-2015, 03:28 PM   #1
Superannuated Member
Aironius's Avatar
2001 19' Bambi
Beaver Lake , Arkansas
Shower Check Valve
Our 2001 Bambi 19 shower has a low pressure issue. When the valve at the spray head is turned on, the water flows in a good pattern of individual needle sprays. But after a second or two it drops to a sloppy dribble. The pressure drop seems to be at the fitting where the hose connects to the wall. It has a rubber check valve with a rather small hole in the center where the water comes through. What is the purpose of the check valve, and what will happen if I remove the guts (besides a better shower)?
Aironius is offline   Reply With Quote
Old 07-10-2015, 07:58 PM   #2
1998 30' Excella 1000
Livingston , Texas
The shower has a shallow "tub" that can be filled with water. Some folks use it to hand wash a variety of items. The shower head/wand can be lowered down into this tub. If you were to do this, and then drain your freshwater lines from a low point (or had a plumbing leak), you could siphon water from the shower into your fresh water lines. Not a good thing. Hence the check valve.
If you think it is the source of your problem, try soaking the fitting in warm vinegar.
Siegmann is offline   Reply With Quote
Old 07-11-2015, 08:46 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
That is a "water saver" perhaps?
Also there is supposed to be a "vacuum break" in the line.
Peace and Blessings..
Channing
WBCCI# 30676
cwf is online now   Reply With Quote
Old 08-13-2015, 11:01 AM   #4
1988 32' Argosy
Dallas , Texas
Same fitting leaking?
I'm having a problem with a leak in my shower and wondering if this is the same fitting you're talking about (not sure exactly how to upload an image, so let e know if you can't see this).
Do y'all know what piece needs to be replaced to make this leak stop and where I might find it? I don't even know what it's called in order to search for it online.
ETxArgosy is offline   Reply With Quote
Old 08-14-2015, 11:06 AM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
no picture.. you have to go 'advanced' then include the file...
Not clear where you are saying it 'leaks'.. inside the shower?
Channing
WBCCI# 30676
Old 08-17-2015, 02:45 PM   #6
Rot-Roo Rastro!!
silversled's Avatar
2000 30' Limited
Similar Question on Shower Valve
Hello,
I have attached a picture of our shower. It has a clear hose issue but before that happened it started leaking around the black plastic where the hose attaches to the supply fixture. Why is it leaking and what do I have to do to replace the part?
Thank you for your help!
Andrea
Astro & the humans I train Barry&Andrea
2000 Airstream Limited 30' ~ Silversled
2005 Ford Powerstroke, 4X4, Crew Cab
AIR #12075
silversled is offline   Reply With Quote
Old 08-17-2015, 03:50 PM   #7
richw46's Avatar
Lexington , Kentucky
Still no picture.
If the picture is on your laptop you'll have to use the "attach" option. That's the button with the paper clip.
Select that, then use "browse" to locate the picture on your hard drive, highlight it and select OPEN, UPLOAD, then the 'close this window' at the top right and you'll get back into your posting.
You won't see the image unless you use the "Preview Post" button just below the box with your text.
After you see the image, scroll down and choose "submit reply" button
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 08-17-2015, 03:55 PM   #8
Rot-Roo Rastro!!
silversled's Avatar
2000 30' Limited
Trying with picture again
Funny, I can see the picture in the post....
AIR #12075
Old 08-17-2015, 04:01 PM   #9
richw46's Avatar
Attachment 245693
Now I can see it, but not in your previous posts
-Rich
Rich & Yvonne
2004 4Runner SE
Old 08-17-2015, 04:05 PM   #10
richw46's Avatar
On our shower, right at the connection, there is a small washer and plastic filter. Your washer might be old/weak or the nylon piece might be missing. Either would cause a leak at that point.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 08-17-2015, 05:06 PM   #11
2002 19' Bambi
Lafayette , California
Perhaps this thread might help: www.airforums.com/forums/newreply.php?do=newreply&noquote=1&p=1670338
Shower vacuum breakers/anti-siphon valves don't last forever and can cause leaks and restrict flow when they begin to give up the ghost.
Tim
Tim A. is offline   Reply With Quote
Old 08-18-2015, 10:19 AM   #12
Rot-Roo Rastro!!
silversled's Avatar
2000 30' Limited
Access to replacement parts?
Hello-
Does anyone know how this apparatus comes apart? Hose comes off and does the black plastic piece unscrew out of the connection? Sorry but I will likely break it without a little direction.
Andrea
AIR #12075
Old 08-18-2015, 07:36 PM   #13
2002 19' Bambi
Judging from your question about the black piece of plastic, it sounds like it is the anti-siphon valve which is giving you the problems. My suggestion is to buy a new one ($16.90 from Amazon: Hansgrohe 06510000 External Vacuum Breaker, Chrome - Vacuum And Dust Collector Accessories - Amazon.com) and look at it carefully to see what part to remove from your shower. In fact, the picture in Amazon might help with that.
If memory serves, the black plastic piece is an internal part of the valve you now have and it and the chrome piece surrounding it unscrew from the outlet.
Tim
Old 08-18-2015, 09:23 PM   #14
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Tim
Ditto.
Channing
WBCCI# 30676
Check valve? Chuck Fresh Water Systems 20 01-31-2006 07:32 PM
Today gate valve, later check valve. GlenCoombe Classic Motorhomes 1 09-20-2005 11:02 AM
1986 AS 345 MH H2O Check Valve Location Jim Tyrney Airstream Motorhome Forums 10 10-21-2003 07:47 PM
Check valve (?) Chuck Fresh Water Systems 9 11-03-2002 09:19 PM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
