Old 08-04-2012, 04:56 PM   #1
2009 31' Classic
Sisters , Oregon
Angry Shower
Just started up after winter..I DRAINED all water. Filled water tank, etc. Everything works except the shower. ???? One thing..the water filter under the sink cracked, so I shut it off..could this b part of the problem?
Mike Kline
mkline814 is offline   Reply With Quote
Old 08-04-2012, 05:51 PM   #2
memgrove2000's Avatar
Elkhart , Indiana
Send a message via AIM to memgrove2000
Did you accidently forget to open the valve on the wand handle? That seem to be an annual occurrence for me.
Mike
Have a great day!
TAC # IN 1 Air#27922
memgrove2000 is offline   Reply With Quote
Old 08-04-2012, 07:28 PM   #3
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
I have had this problem a few times in my prior trailers on my first use after storage. Try removing the wand from the hose, then try to flush out the hose. If water come through, it could be that the shower head is stopped up with the corrosion flushed from inside the pipes and water heater.
Alan
