04-16-2017, 01:17 PM
Journeyman
2016 25' International
Amherst
, Massachusetts
Should toilet bowl hold water?
Hey gang...should the toilet valve seal tight enough so that water is held in the bowl?
Ours is loose enough that water drains right through..and I think it's making smells come up too.
How do I fix?
04-16-2017, 01:20 PM
Manassas
, Virginia
Yes, most definitely it should seal and hold water. That's the primary way it should be setup to flush to ensure a clean flush.
I don't know if you can replace the seal since this has never happened to me. Hopefully you can without replacing the toilet.
04-16-2017, 01:23 PM
2012 27' Flying Cloud
W
, New England
Yes - you need water in the bowl to prevent unpleasant odors from rushing up in to thebtrailer. Is yours a Dometic porcelain toilet? If so, I had one that failed and they sent me a new one. I was able to install myself (and trust me if I can do it, anyone can). Yours should still be under warranty if a 2016, yes? Try calling your dealer and get it fixed asap. If you're not camping for a while, you could seal it with plastic just to keep odors at bay while waiting for the repair.
04-16-2017, 01:24 PM
1993 34' Excella
Estancia
, New Mexico
Yes it should. Was this problem gradual or all of a sudden. If it slowly developed the gasket is probably worn. There used to be a product which would improve the seal but I don't know what it is called. There could be some debris blocking complete closure. Reach right in there and clean the male and female edges of the slider valve. The valve could be replaced but if I was doing the work of removing the toilet I would consider replacing the toilet. The smell may also be due to a clogged vent, I don't think it likely that if the bowl is clean you would get much odor feedback from a leaky slide valve.
04-16-2017, 01:41 PM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
It is common to get something stuck in the groove in the seal. You might need to clean the groove out with a piece wire. Be sure tie a long string on anything you use to clean the groove. Tie the string to something before you start. Then lubricate it with some lubrication from a camper supply place and try it again. If that does not work then you need to change the seal. But yes, it needs to hold water and you will be a lot happier with it when it does.
04-16-2017, 02:05 PM
2009 28' International
Ottawa
, Ontario
Your unit is probably under warranty. If not there are seal kits you can order to repair yourself.
04-16-2017, 02:40 PM
2014 25' FB International
Chesapeake
, Virginia
Replacing seal ring
Our unit in a 2014 and the toilet started to leak. Tried several things to solve the problem but in the end it still leaked. Paid $32.00 for a new seal, pulled the old one out in less then a minute. We did not need to take toilet apart. With gloves on cleaned the area up really well - maybe another 10 minutes. Installed the new seal with no trouble - another minute. The folks at Camping World directed me to a pool service business for a product named "Pool Lube". Everything is working very smoothly - no leaking no smell. We have a Dometic 300 series toilet.
04-16-2017, 04:08 PM
2016 19' Flying Cloud
Austin
As a preventative measure I think you never want to let the seal dry out at any time. Am I remembering that correctly?
Keep some water in the bowl in short term storage or put some lube on it. In the winter time keep some antifreeze in the bowl.
I'm hoping the above is correct and that I'm not leading anyone astray.
04-16-2017, 05:08 PM
1994 30' Excella
Mississauga
, Ontario
when I took mine out of storage two weeks ago it wouldn't hold water. after a few days I tried Thetford toilet seal lube and it worked.
Al
Al and Jean
TAC ON-3
04-16-2017, 05:30 PM
Dazed and Confused
Hillsburgh
, Ontario
Correct but be careful with what type of antifreeze. Do not use alcohol based RV Plumbing winterizer as it will dry out the seal; but instead use a -40 or so windshield washer fluid that is Ethylene glycol based.
Funny thing is, yesterday my wife stormed into the house swearing that someone had pee'd in the AS loo. I told her that I had seen a racoon around during the winter. I use a yellow coloured Rain-X washer fluid.
Cheers
Tony
04-16-2017, 06:39 PM
1986 31' Sovereign
Miami
Try a few ounces of plain old vegetable oil from the pantry. Water off, oil in, work the valve a few times...
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
04-17-2017, 12:46 PM
2006 19' Safari SE
Tucson
I wold be surprised if the gasket on a 2016 would be worn out .. but it could be defective.
But let's hope that it's just dried out and simply needs to be "rehydrated"... This happened to us a few times with the original toilet in our 06 Bambi. We try to keep water in the bowl but a few times it evaporated during storage...then the seal gets dry and doesn't seal well.
With the war pump and the city water off and using gloves, open the slider and feel the under edge of the toilet side of the seal and also the underside of the slider itself...chances are you will feel calcification... Or perhaps there is some toilet paper stuck in the groove where the slider meets the toilet. you can clean these areas with your finger and using a toothpick (don't drop it) to clear the groove. If it's really crusty, you may have to use a little Bon Ami or other cleaning powder on your finger to rub and get the calcification removed. (I'd avoid cleaners containing bleach.)
Once everything is clean, use some kind of lubricant you have handy like thick hand lotion or even vegetable oil to lubricate the gasket ... test the seal .... if it still leaks, add a bit of vegetable oil in the bowl and let it sit for a while to "soak in". Hopefully with a little time the seal with be pliable again and you're good to go. Clean any lubricant residue off the area surrounding the hole at the bottom of the toilet.
To prevent this, leave some water in the bowl when in storage and check it periodically to make sure it hasn't evaporated. You can also cover the toilet opening with plastic wrap to prevent the water from evaporating ... just remember to remove it before you use it!
By the way, we have since replaced the toilet with a porcelain one, which has a different slider mechanism ... and seems to be less prone to this problem.
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
04-17-2017, 01:07 PM
Sag Harbor
, New York
Definitely recommend not using any vegetable oil for this or most other lubrication projects, depending. It will dry out and leave a gummy residue over time, especially after repeated applications.
Like putting linseed oil on antique furniture.
How about this stuff intended for RV toilet seals?
https://www.amazon.com/Thetford-Toil.../dp/B002NSU0ZW
04-17-2017, 01:20 PM
1993 34' Excella
Estancia
, New Mexico
Or you could use a toothbrush. Tie a string to it so if you drop it in you can retrieve it and not have to buy a new one.
04-17-2017, 01:43 PM
W
, New England
Best reply of the day [emoji23][emoji23][emoji23]
04-17-2017, 02:52 PM
2018 26' Flying Cloud
Hot Springs
, Arkansas
Tissue,etc. Can prevent the valve from sealing. Use your towelette bowl brush to clean in and around the seal. Use caution to prevent dropping brush!!!
04-17-2017, 03:22 PM
Journeyman
Amherst
, Massachusetts
Looks like lubrication may be my best first move here...
04-17-2017, 03:48 PM
2008 19' Bambi
2012 23' Flying Cloud
2016 25' Flying Cloud
Bandera
Only if it is an Oral B....they are worth saving
04-17-2017, 04:32 PM
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario
, Ontario
You do NOT want any toothbrush in the toilet; or anything that you have not eaten first..
Just imagine a toothbrush getting stuck in the slider valve in the dump tube.
