Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 06-17-2016, 11:39 AM   #1
1978 31' Sovereign
Grimes , Iowa
Shake Down Inspection
As we prepare and clean out our 78 AS 31' for its maiden voyage to Mount Rushmore, I am finally getting to the plumbing and water supply. I hooked the trailer up to our garden hose and pressurized the system. Voila, everything seems to be working. Flushed out all of the antifreeze and let it run for a while.
I then began to shut the faucets, only to find out the shower does not want to shut off! Is this just a matter of new gaskets? Are the gaskets available at a local home improvement store? Or do I need to change out the faucet?
Any advice would be much appreciated.
tewfiks is offline   Reply With Quote
Old 06-19-2016, 07:25 AM   #2
1978 31' Sovereign
Grimes , Iowa
solution
Okay, here is what I found our about our faucet situation. Home Depot does have replacement cartridges for the Moens that came with the AS.
The Moen cartridge # is 1200
The Danco replacement cartridge is : 80993TS
Easy replacement process and we are back in action again.
Back from Shake down trip and need some thinking outside the tin can nawwin Classic Motorhomes 1 10-15-2013 08:26 PM
Shake down of The Silver Savoy Dot Dave On The Road... 3 10-01-2013 04:33 AM
Kansas City shake down rally for Spring 2011? blmitch5 Forum Rallies & Meet Ups 14 01-23-2011 01:34 PM
First Trip - A Needed Shake-Down Cruise Dr. E On The Road... 6 08-09-2006 07:45 AM
Successful Shake-down Cruise winner On The Road... 8 08-12-2002 01:04 PM
