Old 07-19-2012, 10:25 AM   #1
2010 27' FB International
pocatello , Idaho
Septic Smell
Having a significant septic odor even though we are using the septic chemical additive (non-fomalyn based). Empty waste tank at least every week. It occurs only in the following situations: (1) when we are on the road. Right after trailing it is pretty nasty inside. Can run vents and/or open windows and odor goes away quickly. (2) when we have Fantastic Vent fans running and/or shower vent fan running but don't have enough windows open to provide enough outside air. Does this sound like a toilet seal problem? A vent problem? or something else?
Idaho air is offline   Reply With Quote
Old 07-19-2012, 10:36 AM   #2
2005 19' Safari
GLENDALE , AZ
Summer heat increases odors. Suggest trying formaldehyde-based toilet chemicals (e.g., Thetford Campa-Chem) to see if odor problems go away, or are reduced. If you want to use "greener" products, switch back to whatever you like at end of the season.
Old 07-19-2012, 10:46 AM   #3
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
I was having the identical problem and resolved the issue by replacing the factory issue vent cap with one called Camco Cyclone Plumbing Vent. The vent also resolved the issue on my old Safari. The vent was easily installed by removing the existing cap and replacing with the Camco unit on the existing black vent pipe. It is held in place with 3 screws. Cost is less than $20.
Jim Flower is offline   Reply With Quote
Old 07-19-2012, 11:03 AM   #4
dznf0g's Avatar
Oswego , Illinois
I have found both posts #2 and #3 to have merit. Some environmental situations require the old "blue stuff". You may...I say may...get rid of the odors with a vent change. On my old SOB I installed a 1" computer fan inside and at the top of the vent stack. It powered up whenever the bath light was switched on.
-Rich-
Old 07-19-2012, 12:54 PM   #5
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
RV Digest-It by Unique products is great for dissolving any built up leftovers.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 07-19-2012, 01:01 PM   #6
Crusty's Avatar
1992 34' Excella
See if some sort of critter of the insect persuasion has built a nest and blocked the inside of the black tank vent pipe.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
Old 07-19-2012, 01:05 PM   #7
Ottawa , ON
Yep, could well be a blocked vent (thanks, Crusty)
Old 07-19-2012, 01:09 PM   #8
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Two questions...
1) Does your bowl hold water? It should. If not, when the Fantastic Fan is running it draws the gases in from the tank.
2) Does it hold water but leak out when traveling? If so, the gases in the tank escape when the water seal is broken while on the road.
Shari
Old 07-19-2012, 01:11 PM   #9
Crusty's Avatar
1992 34' Excella
... Don't ask how I know this.
Crusty
Lake Travis, TX
"Rancho Deluxe"
Old 07-19-2012, 01:20 PM   #10
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Crusty, Aage, yes probably a stuck vent, but could also be either rear bath fixture that likely shares the same vent has either no p-trap or the trap is dry. Run a snake or hose down the outside vents. We just fixed that problem on a friend's trailer at a rally this weekend. Old wasp nest in the vent was forcing gasses up the drains which were dry.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 07-19-2012, 04:41 PM   #11
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I've been to Idaho several times and I've never noticed that the Idaho air had a septic smell.
Just saying'.
