Old 11-05-2006, 06:58 PM   #21
1960 24' Tradewind
santa barbara , California
That looks a million times better and more appropriate for these vintage trailers .Id also mention sugarfoot that if you polyurethane the wooden slat
in the shower pan ,the wood will stay as new longer .I like that idea .We have the different bath layout as you know so I don't have the pan .
Scott
scottanlily is offline   Reply With Quote
Old 11-05-2006, 08:09 PM   #22
Sugarfoot's Avatar
1958 22' Flying Cloud
1956 30' Sovereign of the Road
1963 16' Bambi
Southeastern Area , Tennessee
Thanks Scott, that's a great idea! I'll pick up some polyurethane this week. The wood slat mat is an item called "Shower Deck" from Camping World. It gives my mother an extra 1" boost so she has an easier time of it. At about 4'10" even the Lo Profile is a bit much for her. And the deck doubles for use in a campground shower if we ever needed it.
Traveling With Elvis
life with a 1956 Sovereign of the Road
Sugarfoot is offline   Reply With Quote
Old 11-05-2006, 09:15 PM   #23
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
IMO, the water base urathane is the one to use. Seals great with a nice finish, easy clean-up.
Dave
Fyrzowt is offline   Reply With Quote
Old 12-26-2006, 12:45 PM   #24
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Exclamation
I installing a Sealand unit my question is do I use a wax ring like I would in the house or I see this rubber ring.
What the best way to seal the toilet to the floor fitting?
'77 Sovereign Intl 31' CB
Old 12-26-2006, 02:54 PM   #25
China toilets.
China toilets love to come loose from the floor, since they are considerably heavier than plastic toilets. Rear bath or center bath makes no difference.
Add to that lack of proper running gear balance and "no" shock absorbers, will clearly show separation at a early stage of travel.
No amount of any kind of gasket, will stop it from leaking, in very short order.
Old 12-26-2006, 03:15 PM   #26
Sugarfoot's Avatar
1963 16' Bambi
According to my user manual, apply a 1/4" thick by 3/4" wide bead of glazing compound around the circumference of the floor flange if it is being installed in a wet bath or shower stall. That is how mine was installed. Other than that, there should be a bowl seal included with the toilet. If not, check the link in post #10 of this thread for additional parts and such. Don't do the wax ring thing.
As for leaks, I haven't had any yet, but I've only traveled around 500 miles. I'm sure Andy is right, it makes sense with weight differences and imbalance. However, I'm willing to take that risk for the luxury of having "the real thing". Good luck, Bob. I know you're busting your hump right now to get ready for the Can Opener.
Old 12-26-2006, 03:39 PM   #27
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Andy my running gear is perfectly balanced and I have new shocks why would you assume otherwise, now the question is how is it mounted in your 40 years of AS's can you help?
Old 12-26-2006, 03:44 PM   #28
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Thanks, yes tomorrow I'm doing the whole PEX thing and installing this toilet. I see a rubber gasket about 3/4" thick and 1" wide all round is that sound like the seal?
So you suggest a glazing compound......not sure what you mean there?
Old 12-26-2006, 04:10 PM   #29
My comments were directed to Airstream owners in general, as an FYI.
They were not directed to any specific individual.
Old 12-26-2006, 05:38 PM   #30
Sugarfoot's Avatar
1963 16' Bambi
Andy, I thank you for your comments and don't think anyone took them as being directed towards anybody. Since my experience is limited, I'm glad for the heads-up on the possibility of leaks. I wanted to let folks know I hadn't had any so far. But now I'll be watching for unwanted water in the water closet, so to speak.
Bob, a local RV shop installed mine. They tell me they went by the installations instructions, but I don't know what glazing material was used. The illustration in the manual showed application with what looks like a caulking gun. The gasket you have probably is the seal. You can find the manuals at Sealand Sanitation. Sorry I'm not more help than that.
Old 12-26-2006, 06:09 PM   #31
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Lipets,
every RV toilet that was factory installed that I have ever removed had the rubber ring. Dunno why they don't use a wax...maybe exposure to heat? Cost too much?
Aaron
WBCCI #XXXX AIR #2495
Dual Alternator Kit Available for GM Trucks Pick Tow Vehicles 1 10-22-2003 08:11 PM
Water Heater By-Pass Kit Dwight Water Heaters, Filters & Pumps 16 09-24-2002 07:40 PM
LP Tank Mounting bracket kzener40 LP Gas, Piping, Tanks & Regulators 1 08-21-2002 04:40 PM
Antenna Mounting niftypkg Electrical - Systems, Generators, Batteries & Solar 25 08-19-2002 06:03 PM
Ram air Kit rdm Mechanics Corner - Engines, Transmission & More... 0 05-12-2002 09:04 AM
