Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 08-16-2006, 11:04 AM   #1
John Greenlee
John Greenlee's Avatar
Profile:  Bowie , Texas
SeaLand gasket
Hello,
I am in the final stages of replacing the black tank and toilet in a 1966 Overlander. It appears I tightened the toilet bolts too tight and forced the gasket off the flange. What is the proper procedure for tightening the bolts to get a good seal? I am using a SeaLand toilet with a Thetford riser.
JMG
John Greenlee is offline   Reply With Quote
Old 08-16-2006, 09:39 PM   #2
scottanlily
Profile:  1960 24' Tradewind
santa barbara , California
Hello John Greenlee,
they tighten down snug ,not real tite ,as the closet flange ,(black plastic fitting) is plastic and can get crack at the bolt area .I installed a sealand in our trdwnd 1960 ,and had no issue there .I just snug it down equally ,it is not loose and all went ok.Is the seal the right one? as it sounds like that might be
why it squeezed out ,it could be too thick.Generally when the commode is tightened down that's it . check for the right seal .
Scott of scottanlily
scottanlily is offline   Reply With Quote
