Old 10-22-2008, 07:06 AM   #1
SummitAir's Avatar
1970 27' Overlander
Summit , Mississippi
Screwing into fiberglass bath ceiling?
What are the best screws to use when screwing shower curtain track into the fiberglass ceiling of the bath to get a solid hold? Don't want to damage the ceiling experimenting with an inferior fastener. Any help/ideas appreciated.
SummitAir is offline   Reply With Quote
Old 10-22-2008, 10:29 AM   #2
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I would use Pop Rivets. That is what is holding the track in our Caravel.
As screws work going down the road, or using the track the sharp threads, over time, will cut the fiberglass.
I always use pop rivets or "through bolts" to attach things to fiberglass boats for the same reason.
Anyone else have a thought?
Old 10-22-2008, 10:54 AM   #3
2002 19' Bambi
Lafayette , California
Whether you use screws or pop rivets, consider using double-stick tape (the foam type) along the entire length of the track. The mechanical fasteners will provide the strength, the tape will greatly reduce the effects of vibration.
Tim A. is offline   Reply With Quote
Old 10-22-2008, 11:01 AM   #4
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
I have 1 screw holding my medicice cabinet to the wall in the upper right corrner. Don't know if its factory or a PO installed. I suspect a PO. Anyway with my bad axles it viberates loose. I put Red LOctite on a couple of trips back and it has stayed put. I LOVE red Loctite!
Diesel1 is offline   Reply With Quote
Old 10-22-2008, 11:16 AM   #5
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Talking Yep
I agree..
My old 64 GT was the same.
Funny thing tho..the old soap dish was screwed in..
And, it held nicely.
Maybe it had fewer miles ??
53flyingcloud is offline   Reply With Quote
screwing through floating laminate DasAir Floor Finishes 6 04-07-2008 07:02 PM
Painting plastic front and bath ceiling in an Argosy Argy 78 Upholstery, Blinds, Walls & Interior Finishes 10 02-03-2008 03:03 PM
Need Help!!! Fiberglass bath skeeterville Sinks, Showers & Toilets 22 10-24-2007 06:03 PM
Screwing into walls? starflyte1 General Interior Topics 2 03-19-2007 06:33 AM
BAL jack, nut keeps un-screwing Kistler Jacks, Stabilizers, Lifting and Leveling 7 06-08-2006 10:07 PM
