Old 07-08-2010, 10:13 PM   #1
1963 22' Safari
sherman oaks , California
Cool Saniware Toilet
I stepped on the foot pedal flusher of the toilet today . I guess it hadnt been used in over 30 years and I cracked a metal 45 degree angle that is the lever from the flat rod of the rear of the foot pedal to the stopper bolt that lifts the stopper up and down. On the other side of the toilet is the spring but this side has a flat metal rod. I know SaniWave is no longer in business but before I replace the entire toilet, which I would rather not do I was wondering if anyone knew of old parts for this
mmenchel is offline   Reply With Quote
Old 07-11-2010, 09:55 AM   #2
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
SaniWare Toilet
That toilet is actually called a SaniWare and I have a couple of parts diagrams for the 300, 500 and 600 models. Do you know which model you have? Maybe a picture or two would help describe your predicament. I hope these help.
FF
Name:	info front & back pgs 98513.jpg
ID:	106620   Click image for larger version
Name:	info inside pgs 98513.jpg
Name:	Bushing & spring repair kit.jpg
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 07-11-2010, 10:12 AM   #3
1963 22' Safari
Brad thanks! It's part #4 on the last diagram. The bell crank. Where do you think I could get it?
Mike
Old 07-11-2010, 10:15 AM   #4
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Good luck finding any part for a 45 year old toilet but who knows, someone may chime in and say they have one. At least we got the part identified.
FF
Old 07-11-2010, 12:23 PM   #5
1963 22' Safari
thanks loads and I know you're right. I'm also going to try and fabricate 1 out of a little bracket for something else
Old 08-17-2010, 05:23 PM   #6
1963 22' Safari
Sani Ware Toilet '62
I'm reaching out 1 more time...does anyone have any spare parts for this toilet or an old toilet that I can raid (and pay for). I need the bell lever which is the small angled lever that connects the flat rod on the left side to the flushing bolt.
Can anyone help???? If not I will go ahead and see if I can fabricate one myself
New toilet or not? RandyG Sinks, Showers & Toilets 2 02-19-2009 07:39 PM
New Toilet Jfuller678 Sinks, Showers & Toilets 7 01-04-2008 09:19 PM
Toilet, etc 53flyingcloud Our Community 4 06-12-2004 07:23 AM
below toilet tod47d Sinks, Showers & Toilets 10 05-05-2003 09:45 PM
Toilet dmac 2001 Safari 4 12-11-2002 07:29 PM
