Old 02-27-2006, 09:39 PM   #1
Rusty Toilet water: 72 Tradewind
Fellow streamers. I have a lav conundrum.
I purchased a 72 tradewind that is parked, --hooked up to city water. If I don't flush the biffy for a week or two, the fresh water that comes into the bowl is very rusty for about 3 or 4 or 5 long flushes then turns clear. The water from the faucets in the bathroom and cooking area is always clean and never rusty.
I take it that some pipe that exclusively fills the potty has A LOT of rust in it.
Any ideas?? Thanks much..
John
yochanan is offline   Reply With Quote
Old 02-27-2006, 10:08 PM   #2
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
Are you sure it's rust? It could be algae or just sediment. I know it's a crazy question but is it possible that the turlet is hooked up to the hot water line?
Lowes sells a water test kit that you can use to test about a dozen things. The kit costs about $25. it could be helpful to see what is in the water. if it's iron, you'll know. Also Is the bathroom sink or tub or for that matter the toilet stained brown at all. Iron water stains everything (I know because we have high iron at home).
Have you thought about doing a good chlorine flush of your system? I do this before each trip. I superchlorinate the water syystem and run i through the system until it comes out of every point in the trailer. Then let that sit for at least 20 min and then flush several times with fresh water. That may help you...
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
61 Tradewind Water filter lee_jachter Water Heaters, Filters & Pumps 6 12-13-2003 06:24 AM
No water to toilet Oak Sinks, Showers & Toilets 13 11-01-2002 06:31 AM
toilet doesn't hold water.... Chuck Sinks, Showers & Toilets 12 10-08-2002 10:03 AM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 12:03 PM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
