Old 04-20-2013, 09:34 AM   #1
1976 31' Excella 500
Pamplin , Virginia
retractable city hook up and backflows
Im fixing up my 76 31' land yacht that I just purchased. I had to pull the toilet due to the water line breaking and after I shut off the water to the toilet I filled the water tank and it was running out of the city hook up. Is there supposed to be a back flow preventer to keep this from happening?
Also, I pulled the hose out that hooks up to city water and couldnt figure out how to retract it. I assumed that you tugged on it and it had a spring system that would roll the hose back up.
Thanks for any input on both of these questions
Steve
SteveA is offline   Reply With Quote
Old 04-20-2013, 10:06 AM   #2
Steve
There are 2 check valves for the water system.
One is at the rear of the trailer and the other is near the water pump.
Most of the retractable hose systems, quit a long time ago.
Usually the spring goes south.
Old 04-21-2013, 05:07 AM   #3
Pamplin , Virginia
retractable hose
Can the spring system be repaired or should I just cut it off and put a new adapter on.
Old 04-21-2013, 07:25 AM   #4
Best I recall, parts are no longer available, at least from Airstream.
Actuating Arm for Retractable Step(1988-345) robersonwill Classic Motorhomes 3 06-22-2012 07:44 AM
Hook up OR Not Hook up while camping purman Boondocking 29 08-18-2009 06:42 PM
retractable cables gregcarleton General Interior Topics 25 08-16-2007 05:06 PM
Need 30 amp retractable GlenCoombe General Motorhome Topics 12 01-10-2006 05:35 PM
Retractable TV antenna jack simons Audio, Video & TV 1 11-01-2003 09:55 AM
