Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 08-16-2009, 05:49 PM   #1
Profile:  1974 25' Tradewind
seattle , Washington
Replacing toilet flange unit...help!
We are trying to replace the toilet flange and are having a hard time removing it. Is there a trick. This seems to be the only project I can't find instructions for =< Any help or advice will be greatly appreciated!!!
Here's a picture of the problem...
Rawkergrrrl is offline   Reply With Quote
Old 08-16-2009, 06:42 PM   #2
87MH's Avatar
Profile:  1978 31' Sovereign
1987 34.5' Airstream 345
Katy , West Planet Houston, Texas
Images: 242
Yours seems to be a bit different from the one I recently removed from the '78 Sovereign, but here is what I did.
The inner circle should unscrew (if it's made the same) from the tank throat. After unscrewing the inner rotatiing element (the toilet gasket seat) the outer area of the flange should lift off.
To start the inner seat rotating I used a small chisel and a small hammer, and GENTLY tapped (rotated) it out.
Even if you mess up the entire flange I believe the hold down assembly is still available.
More info in this thread:
http://www.airforums.com/forums/f46/...let-53545.html
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Old 08-19-2009, 02:16 AM   #3
Thanks!
That was what I needed to know, thanks!
Toilet Flange on the 88 Ed Emerick Sinks, Showers & Toilets 18 04-15-2009 03:51 PM
toilet flange ?? osolow Waste Systems, Tanks & Totes 6 10-16-2008 12:23 PM
Toilet flange problem Lothlorian Plumbing - Systems & Fixtures 7 07-07-2008 08:18 PM
Toilet Flange won't unscrew!! mello mike Sinks, Showers & Toilets 11 07-11-2005 08:34 PM
Toilet Flange Sneakinup Sinks, Showers & Toilets 16 06-30-2004 03:16 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Mustang Forums - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - RV Forum - Truck Conversion - U2 Music Forum - Campground Reviews - Forest River - Sunline Trailers - Fiat Forum - Retirement Calculator
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© copyright 2002-2010 Social Knowledge, LLC All Rights Reserved.
