Old 09-25-2013, 01:43 PM   #1
1988 25' Excella
Trumbull , Connecticut
Replacing toilet
Hello fellow Streamers. On my 1988 Excella the toilet hold down bolts are ar the 11 oclock and 5 oclock position. I notice that lots of the new toilets have the hold down holes at the 9oclock and 3 oclock positions like the home toilets have.
If I get one of the new toilets how do you move the toilet flange to a different position to accept the new toilet. Are they glued in or threaded ?
Happy camping nm1oqrz
nm1oqrz is offline   Reply With Quote
Old 09-25-2013, 03:58 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
flange
A toilet flange can be moved around to fit your application.
Old 10-16-2013, 04:07 PM   #3
jimmini's Avatar
1989 29' Land Yacht
Mesa , Arizona
Images: 43
Where you able to move the bolts to 9 & 3 ?
I want to change my toilet and mine are at 11 & 5 but I do not remember what the flange looks like.
Bad being old guess I should have taken photo last time I had toilet out.
Also did seal with new toilet work with your flange?
Jimmini :
AKA : TUMBLEWEED. Just an old buzzard with a itch to yonder.
Cowboys have a way of looking at things a little differently than most folks.Their wisdom is simple and more down to earth.
jimmini is offline   Reply With Quote
Old 10-16-2013, 04:27 PM   #4
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I replaced a toilet for a friend. Unfortunately I don't remember the brand but when he bought it at camping world the also sold him an adapter to address the problem.
If your lucky you can turn the flange.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 10-16-2013, 04:49 PM   #5
jimmini's Avatar
1989 29' Land Yacht
Mesa , Arizona
Images: 43
Yes Dometic has a adapter that is $65 at Camping World.
But I would like to put in a Thetford Aqua Magic residence and hope I can tune the flang on my 1989.
I may have to wait till I can look at my toilet and see what I can do.Just that PPL has a very good sale on them till the 18th
Jimmini :
Old 10-16-2013, 05:40 PM   #6
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
If the plywood under the flange is in good shape you could possibly drill through the flange and use the type of closet bolts that are threaded to screw into wood on one end.
Then of course there is always velcro
13 Ram 2500 TD
Old 10-16-2013, 06:06 PM   #7
jimmini's Avatar
1989 29' Land Yacht
Mesa , Arizona
Images: 43
Yep Velcro,duct tape,Gorilla glue and silicon sealer should do it.
Even the parts guy at Camping World said to use the bolt like that so maybe that is how they do it.
Thanks for the help just wish I rememberd how my flange was.Hope it is like the photo in posting above.
Jimmini :
Old 11-10-2013, 09:17 AM   #8
rogerdodger's Avatar
Fresno/Clovis , California
The original flange in mine, the top part is metal,and will turn. I had to cut mine out of the tank destroying it. The plastic flanges available now have 4 holes for toilet mounting, and the residence only needs 2, at 3 and 9 oclock, so just screw the new flange in until tight, then back off until 2 of the bolt holes are at 3 and 9 oclock.
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 11-10-2013, 10:38 AM   #9
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If you use the threaded bolts for wood. You will put holes in the top of the BLACK WATER tank. The original wood on mine was only 1/4" thick. Not much holding power there.
