Old 01-02-2015, 06:30 PM   #29
outdoors717's Avatar
2009 23' International
Milford , Michigan
Put pin in from behind faceplate and behind wall with NN pliers. Just don't lose the pin behind the wall.
Patience on this situation makes all the difference.
outdoors717 is offline   Reply With Quote
Old 01-03-2015, 08:05 PM   #30
2006 22' International CCD
Northridge , California
Originally Posted by Simoneau View Post
After dewinterizing this year I have a slow dribble from the shower even when it is turned off. I think maybe the cartridge needs to be replaced. I've gotten this far:
Attachment 213716
I think the next step is to remove the pin, but it's behind the shower wall. I see other references in this thread to this problem which suggest removing the whole thing, I can't figure out how to do that.
Also, as far as I can tell there's no way to access behind the wall with my layout.
Attachment 213717
Attachment 213718
Could somebody point me in the right direction?
I worked on the same issue this weekend. I found that if you push the valve in you can rotate the plastic piece to a position where the valve comes forward to remove the pin. Look closely at the white plastic "saddle" some notches are bigger than others. Rotate 90 degrees till you find the larges opening to let the valve come forward.
JohnnyAir is offline   Reply With Quote
Old 02-28-2015, 07:03 PM   #31
1971 31' Sovereign
Lake Minnetonka , Minnesota
I'm having issues with my shower temperatures, turning the handle left or right doesn't change the temp, but does this replacement help with water pressure also? I replaced the head of my shower because i thought the original was clogged, but still there is very little pressure, its a heavy drip instead of flow.
bakes is offline   Reply With Quote
Old 08-24-2015, 08:51 PM   #32
2005 19' International CCD
Campbell , California
JohnnyAir - Thanks for the tip! I was trying to replace my cartridge and couldn't figure out how to get that pin out. Rotating the white plastic piece did the trick.
KenS is offline   Reply With Quote
Old 10-18-2015, 03:57 PM   #33
sparkymark's Avatar
2012 25' FB Eddie Bauer
laguna beach , California
I called Moen because my plumber told me that they would warranty the valve replacement. They were very helpful and are sending the new one out immediately!
Ford F-350 crew cab 4X4 diesel, 25' Jack Bauer edition AS
sparkymark is offline   Reply With Quote
Old 08-07-2016, 12:25 PM   #34
2005 19' Safari
Inyokern , California
Ours is a 2005 Bambi with exactly the same problem. The stop plate prevents the valve from being pulled forward so as to reach the spring retainer on the Moen cartridge. An AS expert advised that I need to enlarge the hole in the shower wall. What finally worked for you? Got pics? Thanks a million rivets!
Richcrest
richcrest is offline   Reply With Quote
Old 08-07-2016, 05:12 PM   #35
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by ROBERTSUNRUS View Post
Hi, I have also had this problem with my trailer's shower. On mine, because the clip is inside of the shower wall, I had to totally remove my shower valve, to remove this clip, to remove the cartridge. In this video and in Moen's instruction sheet, It states that you can install the cartridge upside down. Unlike stated above, the only thing that will happen is that when first turned on, it will be hot, and cooler the farther you turn the handle. [instead of cold first and then hot]
Richcrest
Hi, remove the entire valve assembly. Sorry, no pictures.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
Old 08-07-2016, 05:39 PM   #36
dennis3751's Avatar
1976 29' Ambassador
Fitchburg , Wisconsin
Keep in mind that Moen items have a life time warranty. Just look up the faucet model number on line and call the Moen customer service number. They'll want the year purchased and in our experience send a new part free of charge. It isn't next day fast but a great deal if you have the time.
Dennis
dennis3751 is offline   Reply With Quote
Old 08-07-2016, 05:58 PM   #37
2007 22' International CCD
If a Moen faucet is "working backwards just remove the handle turn the valve stem 180 degrees, and put the handle back on. It will now work correctly.
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 08-08-2016, 12:55 PM   #38
2005 19' Safari
"Remove the entire valve assembly" entails cutting a hole in the shower wall at least 3 inches square. Seriously?
Old 08-08-2016, 11:29 PM   #39
Salem , Oregon
Images: 18
Hi, I know some trailers are different; Mine is located in the bathroom sink cabinet. It needs to come out of the back side of the shower. Some trailers also have an access panel to get to the valve assembly.
2005 Safari 25-B
Old 08-09-2016, 05:06 AM   #40
Naper's Avatar
Loretto , Ontario
There is only a couple of different controls. Take your old one to Home Depot or Ace they will have free replacements just ask some one in the store.
Naper is offline   Reply With Quote
Old 08-09-2016, 02:30 PM   #41
Richcrest - If your "2005 Bambi" is a "2005 19" with the rear corner shower, we have the same trailer and the removing the clip holding the cartridge looks impossible. But, the clip can be removed using JohnnyAir's solution... "I found that if you push the valve in you can rotate the plastic piece to a position where the valve comes forward to remove the pin. Look closely at the white plastic "saddle" some notches are bigger than others. Rotate 90 degrees till you find the larges opening to let the valve come forward." Good luck with your project. ~ Ken
Old 08-11-2016, 01:08 PM   #42
2005 19' Safari
Ken S---So did you tie a string or something on that plastic collar so as to not have it fall into the wall once the cartridge was removed?
Replacing Shower Door jmichaelr General Interior Topics 3 07-21-2011 03:47 PM
Removing shower valve in 74 Argosy 24' twilder Sinks, Showers & Toilets 2 04-02-2011 08:28 PM
1981 Excella II shower valve noreen&sal Sinks, Showers & Toilets 2 03-06-2011 08:06 AM
