Old 11-27-2013, 01:46 PM   #21
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 90
Lovely - very clean
AirForums Custom Search
Janet H is online now   Reply With Quote
Old 02-06-2014, 08:22 AM   #22
Dalton, , Wisconsin
Replacement Toilet?
1979 31 ft center bath replacing toilet. Floor rotted around ring- must remove ring To replace floor. Removed screws from ring but still feels attached. ???? Help please. Tom 920_382-6606. newbee
lemonade is offline   Reply With Quote
Old 02-06-2014, 09:59 AM   #23
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Your 25' probably has the toilet mounted up on a raised platform? Measure the height you need before going to the store. Did the replacement on our longer trailer. Had to saw off the old bolts to keep from damaging the plastic flange on the trailer. Used per for the water inlet. Used a riser kit. Get a couple flange gaskets and new bolts.
Airstream changed the valve on the toilet in our 25' because the could do it without removing the toilet.
Old 10-30-2017, 08:07 PM   #24
Wconley's Avatar
2018 28' International
Renton , Washington
Reviving this old thread to say Thanks to those that contributed since I was about ready to return the Dometic 310 I just purchased for our 2009 27FB because it didnít fit even though itís currently standard in the new 27s. I did have to remove and trim the vacuum breaker cover as shown in the pictures. I measured from the center of the lid bolt to the wall and then matched the angle with painters tape. After a rough cut with a saber saw (as shown), I finished smoothing the cut with a Dremel tool. The finished toilet is a big improvement over the Thetford that was in the trailer and they are now sold with a nice solid slow-close seat and lid. Feels just like home. I have a sprayer kit ordered and will install it when it arrives.
ID:	298006   Click image for larger version
ID:	298008   Click image for larger version
Walt
2018 28 International Serenity
2013 F150 Ecoboost
Wconley is offline   Reply With Quote
Old 11-05-2017, 10:47 PM   #25
2007 27' International CCD FB
San Diego , California
Did everyone opt for the standard height 19.75" unit?
I'm leaning towards the 14" low profile one as I have really young kids, and it would help them more than a standard height would help me.
I believe my original toilet is 16.5"?
Boondocking option package:
'07 27FB Ocean Breeze "See Turtle", 3" lift
'09 Lexus LX570, on 33's
Tongue Mount Honda eu2200i - Rear Hitch - Underbelly Storage - Blizzard NXT w/ EasyStart - 3" Lift - 6" Fan Controller
pteck is offline   Reply With Quote
Old 11-05-2017, 11:42 PM   #26
Wconley's Avatar
Renton , Washington
We did but the height matches what we have at home and the grandkids are used to it.
Walt
2013 F150 Ecoboost
Old 11-06-2017, 09:58 AM   #27
I ordered the standard height one as the low profile unit is really meant to go on a pedestal type install.
In researching, seat heights seem to be inconsistent. With some showing 18" to 19.75" as I posted earlier. I believe the seat heigh is 18", and overall height is 20". My original toilet is 17.5", so I should be just fine.
Old 03-18-2018, 04:43 PM   #28
1972 29' Ambassador
AUSTIN , Texas
Originally Posted by SuperTrouper View Post
Hi JGP, Welcome!
If you use the search functions in the browser or the airforum apps you can locate a ton of great information. I would search for search for "winterizing". The way I solved the problem was moving to a place where freezing temps are rare. I've seen many great threads in the forums about how to winterize though. Besides the forums another thing that helped us quite a bit as newbies was this book: http://www.amazon.com/Newbies-Guide-.../dp/B004SUOZCC
Other than that use a "c" in excited or else we will think that you are leaving all the time.
Again, welcome to the Aluminum tribe!
Know of any "newbie" type guides for older AirS's...? 1972. I'm looking for basic diagrams of the water system / gas lines. Need to learn. I'm new to all of this stuff.
Kris
Krisaloha is offline   Reply With Quote
Old 03-18-2018, 04:47 PM   #29
"Silver Shrek"
drairstream's Avatar
2000 27' Safari
Crestwood , Kentucky
You can download all the manual online
drairstream is offline   Reply With Quote
Old 03-18-2018, 05:11 PM   #30
Silver Spud
shadrick5's Avatar
1975 31' Sovereign
Twin Falls , Idaho
Go to airstream.com. Click the company tab, then under the Factory Service heading find and click on Manuals. Input 70's and find '72. Both the owner manual and service manual is downloadable. The service manual will have what you are looking for.
shadrick5 is offline   Reply With Quote
