Old 06-04-2004, 05:21 PM   #1
Zmod's Avatar
Question Replacement shower curtain
When we bought our trailer last fall the shower curtain had been removed and a curtain hanging on a shower rod had been put in. Is there a replacement curtain available out there? Any help is appreciated.
John
Zmod is offline   Reply With Quote
Old 06-04-2004, 08:02 PM   #2
Cedars's Avatar
1983 31' Excella
Waterloo , Iowa
Do you mean like an official Airstream curtain, or what? Or do you mean shower door?
I don't think there is an official Airstream curtain, seems like most buy a regular shower curtain that meets their liking, and cut it to size.
That's what a po did on our 83.....
Elizabeth in Iowa
The carpeting is gone! The carpeting is gone! Long live the cork floor!
Cedars is offline   Reply With Quote
Old 06-04-2004, 08:11 PM   #3
markparker22's Avatar
1984 31' Excella
Santa Barbara , California
Shower curtain
I found that the original folding shower door on my 1984 Excella (mid bath) took up way to much of the entry way for my 6'4" 250 lb. frame. Installing a shower rod and a vibrantly colored shower curtain cut to size was a very good solution giving me the extra 4 inches to tip toe into the shower!
Mark
1984 31' Excella, mid bath, king size bed
1998 Chevrolet Suburban K2500, 7.4L/454 c.i., 4WD, Pullrite Hitch
AIR No. 2375
"You know... life is just the way it is...."
markparker22 is offline   Reply With Quote
Old 06-05-2004, 01:31 PM   #4
Zmod's Avatar
I guess I mean a shower door. I've never seen one so I don't know what I'm talking about (obviously). All I know is that there is a piece of plastic attached to the shower wall which looks like it has had the rest of the door torn off. We put up a curtain rod and shower curtain but thought the original might be a better choice. Are you saying you think a curtain cut to size is a better solution than the original? Thanks for your help.
John
Old 06-05-2004, 01:55 PM   #5
1984 31' Excella
Shower door 1984
Zmod:
For a 1984 31' mid bath Excella the shower door was an accordian folding plastic door with the "pleats" about 4 inches wide. When the door was in the open position the folded pleats stacked up and used up some of the entry way width. With a shower curtain cut to size you do not have this problem. I find that the shower curtain works very well...and it is easy to replace and allows many decorating/color options. My recommendation is to go with a shower curtain.
Mark
AIR No. 2375
Old 06-06-2004, 05:48 AM   #6
GStephens
GStephens's Avatar
1982 31' Limited
1953 25' Cruiser
Hamilton , Texas
I believe the curtain in our 1982 Limited to be original. There is a velcro strip the entire length of the door opening on each side. The curtain itself has velcro attachments evenly spaced every few inches up and down its length. I am also 6'4" and this arrangement works well. There is no loss of entry space in the entry way.
GStephens
GStephens is offline   Reply With Quote
Old 06-06-2004, 08:16 PM   #7
Edie's Avatar
Dallas , Texas
1977 Shower Door Removed
Here's a quote from a thread I replied to on 10-28-02:
I hate to remove something as integral in an Airstream as a built-in shower door, but I confess I did it.
I had a problem in my '77 31 ft. I could open the shower door fine from the outside, but had trouble getting out again.
One cold autumn day in Wisconsin the wind blew out the water heater pilot light. I was done with my shower, and the hot water was gone. I sat in the shower for about an hour, wet and cold. Brett was outside and didn't know I was stuck in the stupid shower. I couldn’t warm up, because the pilot light was out.
Needless to say, the door was gone not much later. If I hadn't been able to make the dogs start barking I might have waited all day for Brett to return.
It was an accordion-fold plastic door. Your POs may have had a similar experience. The sad thing was we had just replaced all the wheeled hangers a few months before.
Edie
Edie is offline   Reply With Quote
Old 06-06-2004, 10:21 PM   #8
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
ZMod,
PO of my 1987 installed a new shower door that is a white vinyl sheet that winds up much like a window shade. Works very well. I would assume they purchased at camping world or similar store.
wingfoot321 is offline   Reply With Quote
shower curtain pattern Lana 1966 - 1968 Safari 31 01-26-2011 11:36 AM
Shower curtain part needed overlander76 General Interior Topics 0 05-09-2004 01:58 AM
Shelf Doors/ Shower Curtain question srgntpepper 1963 Safari 5 01-06-2004 05:03 PM
Is my shower curtain missing something? overlander76 Sinks, Showers & Toilets 1 08-07-2003 06:12 AM
Shower curtain Zed2 Upholstery, Blinds, Walls & Interior Finishes 1 06-24-2002 09:03 PM
