Hey ya'll,
Brand new hope this is the proper spot for my question. Our Sovereign ('71 or'72) has a frozen shower valve. It will not pull out at all. Dave has water everywhere else now with no leaks (I CAN'T BELIEVE I JUST SAID THAT)! I am sure that we will probably need a new valve, and I read a post regarding that, but I want to be sure I understand. Can we replace with a new valve from Lowes or only a trailer type valve from an RV supply? Dave would probably understand better than I, but he spends most of his time with his head inside the water heater compartment.
Also, our water supply has a regulator from the meter to the trailer (on advice from the water dept.). Will we still need a regulator/reducer for full time use? (Using a water hose to check things so far) Thanks!!
Val
