Old 06-01-2009, 09:53 PM   #1
Ottawa , ON
replace bathroom trim?
My Sovereign's "insert nosing", the trim that is held in place in an aluminum track, has gone brown (it's beige when new) and some has even cracked, all due to age.
I bought new stuff to replace it, but it is supposed to slide in from the end, according to the seller.
The problem is that, in the bathroom, there are a few areas where at both ends, the aluminum track is right up against another wall that meets it at 90 degrees, so there is no way to get the trim to slide it into the track to start.
Anyone have an idea how it's supposed to go in?
Here's a picture of one end of a track, to show you what I'm trying to describe.
Old 06-01-2009, 10:03 PM   #2
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
I have heated up... to the point it is almost tooooo HOT to touch! Them pinch it together with your fingers and work both ends into the dove tail chanel of the aluminum! It takes a little doing but it will work! Note: cut it longer than the old shruken piece you are replacing... start at each end and work to the middle, leaving a little speed bump, then work the extra back out to the edges so that it makes a snug fit!
Good Luck Vin....
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 06-02-2009, 03:09 AM   #3
Power to the People !
Maryw164's Avatar
1972 31' Sovereign
SAN DIMAS , California
Send a message via AIM to Maryw164 Send a message via Skype™ to Maryw164
Edgebanding
I will be replacing mine with pvc(?)edgebanding, like what you use on a counter edge. It comes in all types of colors, is flexible, and can be cut to what ever width you need. I will post pics when we complete the renos, and let you know how it turns out.
Mary
Happy Trailering !
Forums member #29232
Check out my new Blogs (work in progress):
http://www.airforums.com/forums/blog...-maryw164.html
http://1972airstreamsovereign.blogspot.com/
Maryw164 is offline   Reply With Quote
bath, nosing, trim
Plastic trim in bathroom chuman70 Cabinets, Counter Tops & Furnishings 31 11-28-2010 04:58 PM
Removing Trim in Bathroom kneal General Interior Topics 25 05-29-2007 06:36 PM
Bathroom trim azflycaster Upholstery, Blinds, Walls & Interior Finishes 7 01-23-2006 09:16 PM
Trim in bathroom kooblekidz General Interior Topics 8 08-01-2005 09:47 PM
Bathroom Counter Trim 74Sovereign Upholstery, Blinds, Walls & Interior Finishes 1 07-10-2002 06:36 AM
