Old 03-20-2016, 04:01 PM   #1
DJW
DJW's Avatar
2004 25' Safari
Lafayette , California
Replace bathroom faucet
Hi, I don't like the two handle bathroom faucet that came on our '04 Safari. It's easy to find a nice SS single handle faucet at home supply places, but I'm not certain how to plumb it. The current faucet has supply lines (red and white plastic running exactly to the very short pipe threads coming out of the existing faucet) will need to be shortened, and then attached to the new faucet via a looped supply hose. Never worked withe Airstream fresh water lines. Can someone point me to info on how to cut, splice, etc. these lines?
Don
DJW is offline   Reply With Quote
Old 03-22-2016, 07:07 PM   #2
DJW
DJW's Avatar
2004 25' Safari
OK, I'll answer my own question. Maybe it will save some time for someone else.
I bought, at Lowes, "Slip" connectors for the Pex piping. Just cut the supply lines to the right length, and reconnected with the connectors. $6 solution.
Don
Old 03-22-2016, 07:58 PM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Don
Glad you figured it out. We've replaced both faucets in our Airstream. Took about an hour in total.
Bob Martel
WBCCI# 5766
Old 03-22-2016, 08:48 PM   #4
2010 27' FB International
La Crescent , Minnesota
My bride wants ours replaced withone that puts my hands closer to the center of the sink. Suggestions?
Jay
mjayjensen is offline   Reply With Quote
Old 03-22-2016, 10:47 PM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Don
Hi, I just read this post. If you click on my "Blog Entries: 51 " you will find how I changed my bathroom faucet on my 2005 Safari. Pictures and explanations included.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 03-23-2016, 09:24 AM   #6
Chelsea , Michigan
Images: 12
Jay
We had the same issues. We went to Lowes and found a bathroom faucet that had a longer reach than the stock one from Airstream (I believe it has a 5 inch reach vs. about 3 inches for the original one.) Replacement is a lot easier if you first remove the sink (it's easy to do this as there are three or four little clips that need to be released first.) The entire installation took less than 30 minutes. On our 2014 Airstream, the fittings were totally compatible with the residential fixture we got from Lowes and we did not need to fuss with any adapters. If you've ever replaced a faucet at home you can do this.
Bob Martel
WBCCI# 5766
Bathroom faucet repair / replacement jesus mike Sinks, Showers & Toilets 7 06-08-2007 10:36 PM
Replace shower faucet in Sylvia/Larry? david b jone Sinks, Showers & Toilets 3 04-24-2007 07:14 AM
HELP!--replace faucet freeshell Fresh Water Systems 5 10-20-2004 07:29 PM
Bathroom faucet replacement billwhelan Fresh Water Systems 1 09-20-2004 08:12 PM
Bathroom faucet and toilet stuff Safari Tim Sinks, Showers & Toilets 5 07-07-2004 04:14 PM
