Old 07-22-2016, 12:26 PM   #1
1970 23' Safari
Rancho Murieta , California
Repair/replace toilet on 1970 Safari
The foot pedal on the toilet in our 1970 Safari broke a couple of years ago. The 'temporary' fix was to remove the remains of the pedal and attaching a vise grip wrench to the brass fitting so that we can open and close the valve (i.e., flush the toilet). Problem is that w/o the foot pedal, we have no water going down the toilet, so we just kept a plastic cup nearby and manually rinsed the bowl. Although functional, we’ve been thinking that we should move beyond the temporary fix and maybe see if we can put in a new toilet. I'm looking for any advice as to how to proceed. I understand that new model toilets may not fit our old trailer without some modification. Unfortunately, I do not know what modifications are needed or what model of toilet would be best. I'm figure that we are not the 1st to want to replace a toilet on a 1970 Airstream. Any suggestions or advice would be greatly appreciated. Thanks!
bsample is offline   Reply With Quote
Old 07-22-2016, 01:06 PM   #2
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
You can replace the broken mechanism but it costs almost as much as a new toilet:
https://www.amazon.com/Thetford-2420.../dp/B0006H934Q
Here's a link to Thetford's conversion chart which may help narrow your choices:
http://www.thetford.com/wp-content/u...t_22x32_OL.pdf
Or, you can call Inland RV [800-877-7311] and they can help match current models to your situation.
Sirs Gawain & Galahad
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Need to repair or replace toilet in 1977 29 ft. Land Yatch Katman104 General Repair Forum 8 10-31-2012 05:09 PM
Toilet: Repair or Replace bilby05 Sinks, Showers & Toilets 17 01-12-2012 08:02 PM
2 replace decal or not to replace? nustreamer Clearcoat, Exterior Paint & Trim 1 07-15-2011 11:28 PM
To replace or not to replace the axles airstrmkids Axles 17 01-13-2011 07:20 AM
1970 Safari floor & frame repair DTMalloy Repairing/Replacing Floor &/or Frame 6 04-24-2008 02:21 PM
