Old 03-18-2018, 01:05 PM   #1
1986 29' Sovereign
Chanhassen , Minnesota
Renovation using w/Airstream shower 203081-01?
I'm looking to renovate my 1986 29' side bath using the Airstream shower 203081-01 (or -2). This turns it to exit to the hall. I'm building all new cabinets so modifications are possible. They are expensive but would save me time, exit to the hall and reduce potential leaks. It appears I would need to adjust the plumbing pipes and maybe reduce the stall height an inch or two.
Has anyone successfully implemented this!!
Thanks, Scott
Harrysheets is offline   Reply With Quote
Old 04-13-2018, 07:35 AM   #2
1986 29' Sovereign
I spoke to Airstream service yesterday. They commented that others have successfully used this but it does require some modifications. It is also the same as shown on the Silver Trailer Supply website (been calling them for 3 weeks with no reply).
From what I can tell the -01 version is used on rear door Airstreams. It appears this means it is on the side of the AS that does not protrude into the hallway as far (not as deep). My 1986 29' mid-bath has the shower and bath together and is about 38" deep from hall to wall.If the shower is only 32" deep then I will have to either widen the hall or mount the shower off the AS inner wall. The latter should help compensate for my AS which has the round body. So far I can see no downsides to using this assembly except for costs (>$1000 plus shipping).
I'm going up to the dealer today to take measurements. and possibly order the stall. More to come
Scott
Old 04-14-2018, 10:43 AM   #3
1986 29' Sovereign
Update - The local AS dealer was very helpful and had a 1995 in restoration. Unfortunately I came away with more questions then answers.
Neither the new AS's or the 1995 matched the shower stall prints. Each had a jog in the seat section which will not allow it to fully sit over the wheel well. This won't work for my trailer. There is too many unknowns for me to purchase a $1000 stall (plus $400shipping) so I decided to go back to the base replacement sold by Inland RV and build my own walls.
Scott
Old 04-25-2018, 08:55 AM   #4
1989 34' Excella
Swanton , Ohio
Which model shower?
working on a complete remodel. So far all interior panels, insulation and subfloor were removed. I have insulated the floor and replaced all but two pc's of subfloor. I left those off because a test of the holding tanks turned up leaky dump valves. Replaced those yesterday. My unit had what I believe is called the mid bath. The shower seat mirrors the wheel well. Previous owner started this remodel and I have no shower parts at all. I looked at a complete shower unit for $1100+ $400 shipping. Not positive that's even the right unit. I have no way to know where the drain was in the previous shower pan? Anyone have any insight here?
Davidhines is offline   Reply With Quote
Old 04-25-2018, 09:45 AM   #5
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Looked on your profile - 1989 34' excella... sidebath? Were 89's before widebody came in? If so curve has changed.
Paula
Old 04-25-2018, 12:01 PM   #6
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
The shower you have is actually larger than the shower you want.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 04-25-2018, 02:25 PM   #7
1989 34' Excella
Swanton , Ohio
I may not have the terminology right. Maybe mid bath?
Its half way down on the right side.
Old 04-26-2018, 07:09 AM   #8
1986 29' Sovereign
The Airstream document archive shows floorplans for a 89 34' side bath. https://www.airstream.com/service/document-archive/ All show the bath on the street side. The "tub" of the shower looks similar to my 86 29'. The opening from my shower enters into the bathroom, not hallway. Dimensions measured from outer sides of tub, center of pipe.. My drain is 6" in from the hallway wall and 15.75" from the shower entry. Yours could be similar but an other owner of your model should confirm. Scott
Old 04-27-2018, 08:57 AM   #9
1989 34' Excella
Swanton , Ohio
Harrysheets
I am not finding the 34' specifically on that site. I see 25, 29 and 32
Old 05-01-2018, 01:16 PM   #10
1989 34' Excella
Swanton , Ohio
Pulling my hair out
I have discussed shower/tubs now with AS, and 3 after market suppliers. Each time it gets cloudy. I canít seem to find a stall or pan and surround for my unit. Seems like I have no choice but to buy a pan and build the walls. Even then Iím not certain which pan to get. AS canít tell me the dimensions of the original. Anybody with this same unit able to break out a tape measure and camera for me?
Old 05-02-2018, 07:06 AM   #11
1986 29' Sovereign
Although this document does not mention the 34' in the title it does show it on the page
https://www.airstream.com/wp-content...6c97a787fe.pdf
shower wand dribbles when not using tenswade Sinks, Showers & Toilets 1 07-06-2014 03:06 PM
Tall Man using an Airstream Shower dickdawson Airstream Lifestyle 23 05-27-2013 05:11 AM
My First Renovation Project: a Simple Shower Head clicknathan Sinks, Showers & Toilets 2 01-14-2013 07:18 AM
Using the shower QuietWater General Motorhome Topics 21 01-25-2008 10:49 PM
using fiberglass to reinforce shower corner charlie tuna Sinks, Showers & Toilets 3 08-31-2006 10:21 AM
