Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 09-02-2004, 11:22 AM   #1
Billyb
Profile:
Removing the toilet base plate
I've seen in the forum that the base plate for the toilet screws into the black water tank, but the advice for removing it doesn't seem to fit my situation. I removed the tolet, and underneath find a black plate with six or so screws holding it to the floor. It seems that it would be screwed in to the tank, but there's not much to grab onto. One preson suggested a strap wrench, but the flange edge is nearly flush to the floor. Suggestions?
Billyb is offline   Reply With Quote
Old 09-02-2004, 11:26 AM   #2
FireFighter
FireFighter's Avatar
Profile:  Currently Looking...
bay city , Michigan
good old screw driver
after removing the screws that hold it into the floor, I used a hammer and screw driver to get it started. place the screw driver on an angle in the direction you need it to spin the blade should be in one of the screw holes for grip then gently tap it with a hammer. (yes I know screw drivers are not chisels) but it worked for me. once the flange is started you should be able to unscrew it the rest of the way.
FireFighter is offline   Reply With Quote
Old 09-02-2004, 11:40 AM   #3
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
If your flange looks like the one in the picture below, I would suggest welding a couple of bolts onto a piece of whatever angle iron you have handy to fit two (of the four pictured) toilet flange bolts. Then you can unscrew the flange using the angle iron.
If you do not have access to a welder, the home improvement stores sell what I call perforated angle iron. This multipurpose stuff is used fairly often to hang garage door runners. Find two holes the right distance apart and screw your nuts & bolts there.
Tom
Old 09-07-2004, 10:55 AM   #4
Billyb
Profile:
Thanks for the help, I just needed encouragement to be more forceful--and a suggestion for the right tool. I whipped up an angle iron one and it worked fine.
Old 09-07-2004, 02:07 PM   #5
Moonshot
The Painted Pig
Moonshot's Avatar
Profile:  1979 Argosy Minuet 7.3 Metre
East Central , Alabama
Images: 14
The flange may be glued into the black tank and trying to forcefully unscrew it may damage the black tank. Try to get a good peek at how the flange is fastened into the black tank first.
Moonshot is offline   Reply With Quote
Old 10-22-2004, 11:20 AM   #6
bake315
bake315's Avatar
Profile:  1994 34' Limited
Elgin , Texas
Images: 161
Noting that Billyb's flange was the type that unscrews from the black tank, does anyone happen to know if they remained this way from '89 to present? I'm guessing this is so, if Firefighter refers to flange removal in his 34'.
Cheers, Dave
"Finish."
AIR #4188
1994 34' Limited / 2002 Chevy 3500 CC 4x4 D/A Equal-i-zer Hitch / Jordan Ultima 2020
bake315 is offline   Reply With Quote
Old 11-10-2004, 11:01 AM   #7
bake315
bake315's Avatar
Elgin , Texas
Images: 161
Never mind - it do!
Cheers, Dave
"Finish."
AIR #4188
Toilet changing tips... drboyd Sinks, Showers & Toilets 2 07-18-2006 02:28 PM
HELP - Removing Toilet Flange Barkingspider Sinks, Showers & Toilets 4 07-12-2004 11:10 PM
64 Swirlomatic toilet MW64OVERLANDER Sinks, Showers & Toilets 1 10-27-2003 10:57 PM
Toilet replacement pinebenny Sinks, Showers & Toilets 2 09-23-2003 12:52 PM
leak at toilet base bbwwjd Sinks, Showers & Toilets 2 09-16-2003 02:33 PM
