Old 06-06-2015, 10:46 PM   #1
Kalamazoo , Michigan
Removing Cowl on Thetford Bravura Toilet
Hello!
I am having trouble with my Thetford Bravura Toilet. I need to remove the cowl around the front of the base so that I can reattach the pedal that controls the water.
I looked at the manual, and it seems that there are little tabs on the inside that clip into the base. I am not having success in pushing the sides in and removing the cowl.
It seems that I should be able to push in the sides and them pull out.
Is there a trick to this?
Kalamazookim is offline   Reply With Quote
Old 06-06-2015, 10:58 PM   #2
1974 Argosy 20
Kooskia , Idaho
When you learn the trick of removal, let me know so I can put the cowling on mine on properly. I have the exact opposite issue, I can't get mine to stay on like it should.
Thetford Bravura Leak dznf0g Sinks, Showers & Toilets 0 10-08-2012 05:06 PM
Thetford Bravura Closet Flange gasket dznf0g Sinks, Showers & Toilets 7 08-24-2012 07:54 AM
Removing Thetford Toilet from 1963 Bambi Aktundra Waste Systems, Tanks & Totes 1 10-20-2011 10:53 PM
Need help with Bravura Flange Seal spat61 Sinks, Showers & Toilets 2 10-13-2009 12:41 PM
Bravura Toilet mtbob Sinks, Showers & Toilets 6 12-22-2002 02:19 PM
