Old 01-15-2010, 06:51 PM   #1
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Remove Sink
Not sure of the mechanics of this drain.The ABS has sides for a wrench but seems to be glued to the pipe.Usually there are threads.There is a metal nut above but no room fo pipe wrench.Is this stock or new install?Could I go in from the top?
ID:	94138   Click image for larger version
bwaysteve is offline   Reply With Quote
Old 01-15-2010, 07:00 PM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
You need to loosen the low profile gray nut just below the sink and then from the top use two screw drivers to twist out the drain basket.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 01-15-2010, 07:27 PM   #3
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Lee, Low profile spanner wrench I guess would work for the nut(not much room).My bathtub four prong is too big so will try the screwdriver approach from the top.Does this drain look original to you?I have never seen one that was all glued.
Thanks as always Lee.Steve
Old 01-15-2010, 07:42 PM   #4
1967 22' Safari
1960 Caravel
Images: 8
The drain is setup that way on my 67.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 01-15-2010, 09:14 PM   #5
65Safari65's Avatar
1965 22' Safari
Staunton , Virginia
That's what my '65 looks like. Watching with interest.
65Safari65 is offline   Reply With Quote
Old 01-15-2010, 11:04 PM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
What you should use for that drain nut is this wrench, available from most hardware stores:
Old 01-15-2010, 11:36 PM   #7
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Terry, I bought one just like that yesterday,but that wing nut gets in the way.
Have you used this before for this app.?I guess I was tired from all the other tearout.I will attempt first job of the day.
Old 01-16-2010, 06:25 AM   #8
1967 22' Safari
1960 Caravel
Images: 8
The tool Terry suggested should work. You may have to try different angels, flip it over ect.. As you spin out the basket that gray nut will want to tighten. Just something to keep in mind.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 01-17-2010, 09:35 AM   #9
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Thanks All,
Do not see any screws for attaching countertop.Am I just blind,on is this thing glued on?
Old 01-17-2010, 10:38 AM   #10
1967 22' Safari
1960 Caravel
Images: 8
I took the whole unit out with counter top attached. It was a little tricky with the drain. My counter top was screwed on with flat head screw in the door frames (front) and with long screws in the back through the board that holds the top part of the counter to the wall. Hope this helps.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 01-17-2010, 01:11 PM   #11
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Lee,I have the screws on the back board holding the counter.Did you lift over the furnace or remove the furnace first?I look for hidden screws 3 times and usually find one on the third.Thanks Lee.
Old 01-17-2010, 01:28 PM   #12
1967 22' Safari
1960 Caravel
Images: 8
From my understanding the furnace was in before the cabinet so you should be able to just move the whole thing away from the wall without the furnace being in the way. Once you find all the screws. The drain should be the only tricky part when you remove it.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 04-25-2010, 08:53 AM   #13
2005 25' International CCD
Newport , Arkansas
Pop-up drain removal
The underside of my bathroom sink looks like the pictures displayed. I can't figure out how to get the pop-up drain out of the sink. It turns about a half turn to be up or down. How do you get it all the way out?
eggman is offline   Reply With Quote
Bathroom Sink grovelander Cabinets, Counter Tops & Furnishings 2 10-20-2007 06:40 PM
Bathroom Sink Lee Pace Sinks, Showers & Toilets 1 08-20-2006 10:51 PM
One sink, two sinks, red sink, blue sink? Janet H General Interior Topics 7 07-26-2006 06:17 PM
Under sink cabinet [What's this ?] niftypkg Cabinets, Counter Tops & Furnishings 2 12-14-2002 01:26 AM
