Old 03-21-2008, 08:50 AM   #1
1966 28' Ambassador
1965 30' Sovereign
1972 31' Sovereign
rutherfordton , North Carolina
Remove 72 Sovereign Toilet
I'm sure there is something I am missing in the easy process of simply unbolting the toilet so as to replace the flooring in the bathroom but I can't see what it is. There are no bolts in the front so they must be in the rear but I just can't feel them.
TIA,
Lance
acanthus is offline   Reply With Quote
Old 03-21-2008, 10:17 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
There are two 1/2" hex nuts holding your toilet down. One should be in the front, one in back. The front one can be accessed through the foot pedal area, the rear one will require hanging over the toilet and using a wrench.
Old 03-22-2008, 09:06 PM   #3
1972 25' Tradewind
Madison , Wisconsin
My toilet had an acess tab on the left side under the seat. I still couldn't get the wrench on the nut & had to enlarge the hole. Look and see if you have a square tab on the top left side of the bowl???????? Of course that assumes the same type of toilet.
Smokin Camel is offline   Reply With Quote
Old 03-22-2008, 09:35 PM   #4
1976 25' Caravanner
Campton , New Hampshire
Do a search on this forum for "1972 thetford aqua magic 30" , I copied the procedure from the manual. This would be for the toilet in an international.
ticki2 is offline   Reply With Quote
Old 03-23-2008, 05:08 AM   #5
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Try this
Aqua Magic four owners manual - 1
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 03-23-2008, 05:16 AM   #6
Lothlorian's Avatar
Loganville , Georgia
I could not find mine either. I got on my hands and knees wearing poly gloves and started feeling around. There was bees wax all over the bolts and nuts. Once I removed it I decided not to mess around. I got my reciprocating saw out and cut the bolts. My floor was coming out anyway.
SIU Bound
Brian
Lothlorian is offline   Reply With Quote
Old 03-23-2008, 06:17 PM   #7
SharonIvey's Avatar
1972 29' Ambassador
Red Oak , Texas
We just got ours out today. The mount bolt had become loose and finally we just had to pull it up. We need a part or two or simply may replace with a brand new porcelain/china toilet just to have improved access.
You'll get it. To get to the one behind the petal, you have to wedge the toilet open and be careful not to let your wedge drop into the tank.
SharonIvey is offline   Reply With Quote
How do I remove the Tub??? Morning Dew Sinks, Showers & Toilets 21 11-26-2016 07:37 PM
Can't Remove Window bentguy Windows & Screens 7 10-01-2008 11:47 PM
?How to Remove Inner glass? Blu_Hwy_Lady Windows & Screens 7 12-17-2006 08:15 PM
Remove toilet to to put in new tile dmadam Sinks, Showers & Toilets 2 11-02-2004 03:30 PM
remove/reinstalling the toilet Chuck Sinks, Showers & Toilets 7 07-28-2003 02:44 PM
