Old 04-22-2008, 09:12 AM   #1
2002 31' Land Yacht 30
Ottawa , Ontario
Refinishing the kitchen sink
Hi!
We have a 2002 Land Yacht motorhome. The paint at the bottom of the kitchen sink has peeled off. My wife wants it refinished ! I tried to get a guy who does bath refinishing to come over and have a look...Still waiting!
I am thinking of removing the sink to get it redone with powder coating. The problem is to remove it. The sink is attached underneath to the Corian surface by brackets. I cannot get to the screws because of the cabinet itself.
Any suggestions?
Thanks, Remi
48-remi is offline   Reply With Quote
Old 04-25-2008, 10:52 PM   #2
1977 31' Sovereign
Prineville , Oregon
Remi,
There are products you can finish it with, but most require spraying to get a good finish. Por15 makes a catalyzed white coating for refinishing sinks and bathtubs that should flow out OK. Here is a link and they show it being applied by brush. I have some on order, but haven't recieved it yet.
WHITECOTE-POR-15 Inc.
David
DasAir is offline   Reply With Quote
Old 04-26-2008, 08:09 AM   #3
musketeer's Avatar
1989 25' Excella
Kimball , Minnesota
Refinishing sink
Remi,
The "bath refinishing guy" will probably use an epoxy acrylic type of catalyzed coating. This type of product works better for tubs and showers than it does for sinks. The difference is the result of pots, pans, dishes, silverware, knives, etc banging against the finished surface vs. a person's bare skin. I suspect that the "bath refinishing guy" will want $100 to $300 to repair and refinish your sink, it will look great until the process starts all over again. I have used epoxy acrylic finishings for showers, wall tile and counter tops. They work great for these applications. Sinks are not recommended. Here is the link to Midwest Chemical which explains the products and processes that the "bath refinishing guy" will use: Midwest Chemicals - Bathtub Refinishing, Countertop Refinishing, Concrete Staining, and Truck Bed Liner industries
I have not used the Por15 product on sinks, but have used them on my metal frame with excellent results. It might be a better option as a "do it yourself" project and if someone else has used it maybe they can comment. Maybe a new sink is the best option, though. Good luck!
musketeer is offline   Reply With Quote
Old 04-28-2008, 01:26 PM   #4
Ottawa , Ontario
Hi,
Thanks for the advice. I will also check what is avail at the hardware store.
Remi
Airstream L/Y 30
2006 Vibe
2004 Miata
Old 04-28-2008, 04:30 PM   #5
enduroryda's Avatar
1994 21' Sovereign
Down on the corner... , CT
Here are some pics I pulled from M&M and what she did in here trailer with the POR 15. It came out awsome. POR makes a great product.
Ann & Eric
WBCCI 6274
TAC CT-4
NEU
enduroryda is offline   Reply With Quote
Old 04-28-2008, 06:38 PM   #6
jimmickle's Avatar
2000 31' Land Yacht
Marion , Iowa
The same thing is happening to the sink in mt 2000 Land Yacht. I called Jackson Center and they recommended replacing it, as if it was easy to get out and in!! Since the base sink is stainless, I hope to just remove the existing finish and have a SS sink.
jimmickle is offline   Reply With Quote
Old 04-28-2008, 07:19 PM   #7
silvermoon's Avatar
1967 24' Tradewind
1963 19' Globetrotter
1961 24' Tradewind
Silver City , Motorcourt
We just happened on this thread. POR is a really good product. We, just happen to sell the stuff. They have lots of products that work really well on Airstreams. The have a brush-on clearcoat, a clearcoat stripper, an aluminum cleaner/wash/prepolish and many other products that we use in our Airstream restorations. We would be happy to send anyone a catalog that is interested. And a fantastic rust inhibitor (for frames), just use their cleaner and their paint and the rust won't come back!
_______________________________________
_________________________________________
PEACE!
Holly
silvermoon is offline   Reply With Quote
Old 04-29-2008, 05:16 AM   #8
musketeer's Avatar
1989 25' Excella
Kimball , Minnesota
Sounds like the sink in these motorhomes is stainless steel which is then finished with some type of coating, which is now chipping and pealing. Unfortunately the Por 15 won't have anything good to "stick" to unless the old finish is complely removed. The picture from the previous post shows an enamel sink being refinished, Por 15 would work fine in that situation. And yes, the Por 15 products are great. I used their stripper to remove my clearcoat and have the products to refinish my frame. Good stuff, but not right for this sink.
Old 04-29-2008, 01:08 PM   #9
bobfowler's Avatar
1972 Argosy 20
2007 Base Camp
Middletown , New Jersey
Images: 14
Sweet! Hmmm.... Maybe the "70's Harvest Gold" can go away...
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
TAC - NJ-007
bobfowler is offline   Reply With Quote
Old 05-06-2008, 09:45 PM   #10
Ottawa , Ontario
Hi,
I got a two part epoxy enamel at my hardware store. 30 $ + 8 $ for the cleaner...and a brand new brush to do a decent job. I hope it will last. We always use a rubber mat in the sink...
Remi
Old 05-07-2008, 09:12 AM   #11
jimmickle's Avatar
2000 31' Land Yacht
Marion , Iowa
What did you do to prep it before painting?
Jim Mickle
Old 05-08-2008, 09:37 AM   #12
Ottawa , Ontario
Not done yet, it is too cool. I need a temperature of 75 *F as a minimum.
Prep requires applying a TSP type cleaner with an abrasive sponge. The product is Klenk's Epoxy Enamel by Swing Paints of Montreal, Quebec.
Old 05-08-2008, 09:52 AM   #13
jimmickle's Avatar
2000 31' Land Yacht
Marion , Iowa
How did you get the old, bad, paint off?
Old 05-09-2008, 09:06 PM   #14
Ottawa , Ontario
I used sandpaper. The bottom of the sink is pretty much cleared of paint. I intend to clear the whole bottom so the transition to the sides, when I refinish it will not show too much. I hope to do as nice a job as that red sink!
Remi
need new kitchen sink shantz Sinks, Showers & Toilets 4 03-24-2008 08:48 PM
Shower sink Refinishing LRPorter All Argosy Trailers 4 03-12-2006 06:08 PM
What size kitchen sink strainer? RonJudi General Motorhome Topics 4 02-19-2004 12:06 PM
Kitchen sink Cutting board. Joan D'Andrea Cabinets, Counter Tops & Furnishings 1 11-07-2002 11:57 AM
Kitchen sink lites FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-15-2002 10:17 PM
