Old 06-02-2016, 11:56 PM   #1
st johns , Florida
Problem with electric toilet flush
Our domestic 8100 toilet stopped working mid flush. The tank says it is at 19% so it's not full. No water coming in or going out. Just completely not working when the switch is pushed. Any ideas?
dclanfranchi is offline   Reply With Quote
Old 06-03-2016, 01:21 AM   #2
2016 30' Flying Cloud
2017 30' Flying Cloud
Dallas , Texas
Good morning,
I had the same symptoms a few months ago. Check for a blown fuse. I have a 2016 30' Flying Cloud with that toilet. I believe it was fuse location nine and the red light only shows up when you push the flush button. Just open you converter box and watch the dc fuses block when trying to flush.
Regards,
J
TXWind is offline   Reply With Quote
Old 06-03-2016, 07:19 AM   #3
Gainesville , Florida
Electric toilet flush, boy am I behind the times!
Old 06-03-2016, 07:24 AM   #4
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I'm the leader of the gear head world,
However I want to manually flush the crapper!
Old 06-03-2016, 09:13 AM   #5
st johns , Florida
Originally Posted by TXWind View Post
Good morning,
Regards,
J
That's seems to be it. Thank you! On our way to buy some new fuses. Hopefully whatever made the fuse go out will resolve with a new fuse too.
Old 06-05-2016, 06:48 PM   #6
bigmikeeb
bigmikeeb's Avatar
2015 30' FB FC Bunk
2013 27' Flying Cloud
Vancouver , Washington
Toilet Flush
I've got a 2015 Flying Cloud Bunk and have the same problem. Every time there was matter to be flushed, the fuse would blow. The dealers fix was a bigger fuse, but in talking with a factory tech, that is neither safe, nor the correct repair. I have another appointment with the dealer and hope this can be resolved.
bigmikeeb is offline   Reply With Quote
Old 06-08-2016, 11:07 AM   #7
st johns , Florida
We will have to add it to our list of repairs that need to get done before the warranty is up. We replaced the fuse and a few days later, it blew out again. And we replaced it but it definitely seems funny.
Old 06-08-2016, 12:51 PM   #8
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Fuses blowing indicates excessive current draw, may also be caused by too much load on the motor, a short, or low battery voltage. Or a combination.
Doug and Cheryl
Old 06-09-2016, 10:58 AM   #9
st johns , Florida
Hmm. The second time the fuse blew was when I was filling an empty toilet. What do you think could have caused it?
Old 06-21-2016, 05:50 PM   #10
ILOVESALLY's Avatar
2007 25' Safari SS SE
Sarasota , Florida
I had same problem on 2016 bunkhouse. It was fuse no.7
ILOVESALLY is offline   Reply With Quote
Old 07-02-2016, 06:20 PM   #11
bigmikeeb
bigmikeeb's Avatar
2015 30' FB FC Bunk
So I stand corrected. The dealer researched the information on the toilet and found that the bigger fuse WAS called for. Apparently it left the factory with a 15Amp fuse, and it actually takes a 20Amp. Dealer reports that this is not an uncommon problem, so if you are having problems, check the fuse amperage to make sure it is right.
Old 09-07-2017, 01:48 PM   #12
San Francisco Bay Area , California
Yep, same thing over here.
First month in my 2017 FC 26U, same issue, same fix. Left the factory with a 15A and the schematics/labels show it should be 20A. So glad to have the forums to guide and/or confirm my troubleshooting and solutions. Thanks, all!
Take care!
e.moody.d is offline   Reply With Quote
Old 10-18-2017, 11:40 AM   #13
2016 26' Flying Cloud
2011 25' FB Flying Cloud
reno , Nevada
I had the same problem with my 2016 26U. After checking all electrical possibilities, it seems the solenoid went bad. Called Airstream and they sent out a part, had it repaired and now works great. Also FYI, there is a screen in the solenoid that can become plugged with debris. That can also cause the water not to flow when the button is pushed. The solenoid is located under the bathroom counter and accessible through a plate located in the cabinet.
jomondnv is offline   Reply With Quote
Old 04-30-2018, 04:43 PM   #14
Wyknot1's Avatar
Peru , Illinois
Fuse ok, still not flushing.
My toilet will fill with water, but the flush button is not working. The fuse is fine. Any ideas?
Wyknot1 is offline   Reply With Quote
My toilet won't flush on city water godaddy64 Plumbing - Systems & Fixtures 12 09-18-2011 02:37 PM
64 overlander toilet flush pedal surfscoter Sinks, Showers & Toilets 7 03-07-2011 12:30 PM
'75 Argosy trailer toilet 'flush water leak' Derek Gardner Sinks, Showers & Toilets 2 10-26-2010 07:04 PM
Toilet Flush Peddle for a Sea Land 510 Tin Lizzy Sinks, Showers & Toilets 1 08-07-2006 02:24 AM
Perma Flush Toilet COArgosy78 Sinks, Showers & Toilets 1 07-20-2004 11:12 AM
