Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 06-09-2007, 12:07 PM   #1
Tidal
Tidal's Avatar
Profile:  1972 31' Sovereign
Cordova , Tennessee
pre fab showers available?
I'd like to remove old set up and insert a new pre fab walk in shower stall. any ideas? Anyone ever heard of doing it w/ aluminum? Many thanks!
Tidal is offline   Reply With Quote
Old 06-09-2007, 12:32 PM   #2
tphan
tphan's Avatar
Profile:  1972 27' Overlander
estes park , Colorado
hi- I doubt you'll find a pre-fab shower unit that would fit the curve of your walls. You can get just the shower base and then fashion some waterproof walls around it, or just a curtain like I did. Alum. walls would certainly look good, I think! good luck- tim
tphan is offline   Reply With Quote
Old 06-09-2007, 03:16 PM   #3
Condoluminum
Condoluminum's Avatar
Profile:  1988 25' Excella
Sunnyvale , California
Look at RV Shows..
If you go to local RV show or dealers with lots of inventory, the stickers from the manufacturers are still on the shower stalls that are installed as complete units. I think Indiana Fiberglass is one of the larger makers, including the circular units. It is unlikely, though, that a rectangular unit will work with curved side walls in Airstream well, so you may have to start with shower pan from Home Depot or Lowes, and work with aluminum sheet on side walls to make your own... I've never seen one made of aluminum...
Condoluminum
Condoluminum is offline   Reply With Quote
Old 06-10-2007, 12:58 AM   #4
Tidal
Tidal's Avatar
Cordova , Tennessee
Thanks!
Old 06-14-2007, 09:14 PM   #5
malconium
Profile:  1973 31' Sovereign
Portland , Oregon
RV parts suppliers carry various types of prefab bath and shower bases that you could use as a start for making your own shower enclosure. I am pretty sure that someone on the forums would have made and enclosure using aluminum. I have seen one that used copper and others that have used various types of plastic. One place to check out is the following RV supply place:
Leading the WORLD in RV Parts Sales - RV PARTS OUTLET
Just type shower in the search window on the right to see what they have available. There are other places that carry such things too. RV products tend to be a bit more compact than ones that you would find at Home Depot but you may be able to find something that works there too (a shower pan not the whole thing).
Malcolm
malconium is offline   Reply With Quote
looking for Pre '70s Floor Plans... Julian Member Introductions 2 05-07-2007 07:34 PM
Pre Buy Inspection tolmied Our Community 0 12-01-2006 01:21 PM
Pre Wired for Heat 68 Safari soldiermedic Furnaces, Heaters, Fireplaces & Air Conditioning 3 11-21-2006 03:52 PM
MH pre buy suggestions jkleven Airstream Motorhome Forums 13 03-27-2006 08:21 AM
pre 1993 whats better? vagabonds Our Community 0 03-22-2002 08:09 AM
