Old 08-07-2017, 03:28 PM   #1
1966 22' Safari
Keizer , Oregon
Porcelain toilet repair problems
I'm having a continuing problem with the porcelain toilet on my 1966 Safari becoming separated from the Thetford Slide-O-Matic valve below it. There are five holes in the bottom of the porcelain bowl which should stay bolted to the valve, but I can't seem to find any type of anchor to insert in the holes which will keep the valve firmly attached. Has anyone else had this problem and found a way to fix it?
thekernals is offline   Reply With Quote
Dometic 310 Porcelain Toilet Upgrade BoldAdventure Sinks, Showers & Toilets 28 02-06-2016 08:29 AM
Porcelain burner diffuser thingy '62 or '63 Andrew M. Franklin Refrigerators 2 11-02-2012 08:38 PM
Townsend Porcelain toilet repair. toothDr Sinks, Showers & Toilets 10 05-25-2009 04:37 PM
Water Heater Fix - Try drying the porcelain electrode guy.random Water Heaters, Filters & Pumps 1 10-23-2007 04:59 PM
Thetford porcelain to slide valve gasket ? IndianaJeff Plumbing - Systems & Fixtures 8 04-24-2006 03:07 PM
