Old 01-22-2014, 07:10 PM   #113
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I wouldn't think the latches go on the backs-
I would think the latches go on the drawer fronts and cabinet faces- but I don't know for sure-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 01-22-2014, 07:11 PM   #114
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
My plastic current ones are on back - these are comparable in size and I think it will work out - may try an install tonight
PharmGeek is offline   Reply With Quote
Old 01-22-2014, 07:25 PM   #115
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
That's how they are mounted on the larger drawers and doors. Would definitely have to use a stubby screwdriver to mount the socket half in the confined opening of the smaller drawers. I expect there would be an alignment issue for the hook to enter the housing as the drawer is designed with vertical movement as it closes and theses catches don't have much tolerance.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 01-23-2014, 10:07 PM   #116
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
4 installed - the bottom 3 are installed like in the photo - the top one is installed at the front of the drawer
At lowest "tension" - these are noticeably tighter - ill end up torquing them down just a tad more and I think they will hold when driving but we shall seeClick image for larger version
Name:	ImageUploadedByAirstream Forums1390540041.415932.jpg
Name:	ImageUploadedByAirstream Forums1390540053.491558.jpg
