Old 01-22-2014, 11:26 AM   #99
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Name:	ImageUploadedByAirstream Forums1390415180.766315.jpg
PharmGeek is offline   Reply With Quote
Old 01-22-2014, 11:54 AM   #100
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
No travel latches- the drawer slide mechanism requires you to lift the drawer up first before you pull the drawer out- but traveling on bad road seems to make both actions happen simultaneously-
If, after balancing the wheels, my underwear drawers still want to come out I will try some of those travel latches.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 01-22-2014, 11:59 AM   #101
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
no no, I confused you I think....not a travel latch...what is the term again...these go on the inside back of the drawer....when your drawers close they likely produce a "SNAP" sound and they are held in place by a similar snap mechanism....you cannot see these unless you take drawer out like you said and look inside the back part of the drawer....does that make sense?
ill look up a pick - but these are not externally visible in operation...
Old 01-22-2014, 12:00 PM   #102
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I assume your classic has these already installed....
http://www.amazon.com/gp/product/B00...pf_rd_i=507846
Old 01-22-2014, 01:17 PM   #103
m.hony's Avatar
2013 30' Classic
Nothing like it in my Classic-
Nope- no snapping sound-
Nothing inside the drawers but the inside of the drawers...
The drawers in a Classic are just like the drawers in your bathroom and kitchen at the stick and brick abode.
Another difference in a Classic and a Flying Cloud- like the a/c units and the plumbing-
TAC #MS-10
Airforums #70955
Old 01-22-2014, 01:21 PM   #104
m.hony's Avatar
2013 30' Classic
Amazon.com: RV Designer Collection H316 10-lb Push Latch: Automotive
Nope.
Nothing.
I ain't confused at all...
The only thing that keeps the drawers in place in a Classic is the fact that you must lift the drawer up before you pull out on the drawer-
No latch whatsoever-
Like I said earlier- If balancing the wheels doesn't keep the drawers from coming out I will get some of those latches you pictured.
For now we will continue to take the drawers out and place them on the floor prior to rolling-
Another thing that would work is those child proofing latches you put on the cabinets and drawers at the stick and brick house-
TAC #MS-10
Airforums #70955
Old 01-22-2014, 01:22 PM   #105
m.hony's Avatar
2013 30' Classic
Even the overhead lockers have no latch-
They are simply held in place by spring tension in the little support rods that hold them open.
TAC #MS-10
Airforums #70955
Old 01-22-2014, 01:55 PM   #106
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
ahh - we have the "click" sound of our latches when closing - I may resort similarly to taking them out if these prove insufficient
You have to lift yours? Would they come out in travel ?
Old 01-22-2014, 02:32 PM   #107
Alumitater's Avatar
2007 25' Safari
Spanish Fort , Alabama
Latches
These latches look outstanding....did I understand you ordered them from Amazon or the source mentioned in your earlier link?
Much enjoyed meeting you and family at Canopener.
Tom and Robin
2007 Safari 25' FB Twin
"If you have to go through a minefield....follow somebody"
Alumitater is offline   Reply With Quote
Old 01-22-2014, 02:33 PM   #108
m.hony's Avatar
2013 30' Classic
On bad roads, yes, they come out- roads so bad as to make 2 motions- up and out- are amazing to me.
I still think it could be a wheel balance issue as it only happens from the wheels back. from the tongue to the axles you can place a glass of water on the floor and it will not spill-
If wheel balancing doesn't stop the drawers from coming out I will put child latches or travel latches in them- or just continue to place the drawers on the floor prior to travel.
We also place the shower head nozzle/hose thingy in a towel on the shower floor. It has come out of its holder and swung around violently during travel and put a nick in the shower wall.
We no longer use the soap dispensers- they will come out during travel and soap will run all over the floor.
With the regular toilet we have to flush before travel, but after disconnecting from water to keep the water in the commode from splashing out on the floor.
When we arrive at our destination, I make sure the kitchen faucet sprayer connection is tight- otherwise water leaks in the cabinet under the sink-
Rough roads do crazy things to a trailer-
TAC #MS-10
Airforums #70955
Old 01-22-2014, 02:34 PM   #109
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Through the link "lee valley" as I recall
A bit pricey - I couldn't find on amazon personally
Thanks btw - nice to meet you too!!
I'll give a review of the hardware after a couple trips this year
Old 01-22-2014, 03:06 PM   #110
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I use a soap dispenser but remove them from base attached in shower to secure location during travel
I never thought about the shower head - good call
Old 01-22-2014, 03:19 PM   #111
m.hony's Avatar
2013 30' Classic
It was good to put a lot of names (Airforums handles) with a lot of faces at Canopener.
It was good to meet you and you family.
Maybe we will meet again somewhere on the road.
Our trailer has residential style soap dispensers by the kitchen and bathroom sinks.
The drinking water filter has come loose during travel as well.
I just leave it off all the time and drink bottled water.
TAC #MS-10
Airforums #70955
Old 01-22-2014, 07:07 PM   #112
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Plumbing Problem??
I haven't had a problem with the 3 "flavor" dispenser I mounted in the shower, but it slides down onto the mount about 2" and seems secure enough. The shower head rides on the floor along with a plastic basket holding the wife's foo foo stuff. I also put the Corian sink covers in a secure spot under the sink.
Back on topic, I have the (plastic) latches you described on doors and the drawers under the bed that run on metal drawer slides, but the galley drawers don't use the slides and the only thing holding them shut is the small horizontal slot the front end of the drawer drops into when it is fully closed. A good bump can easily dislodge the drawer and any subsequent movement will let the drawer open. I would be interested to learn how you installed these catches on the rear of these drawers, access seems limited.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
