Old 01-15-2014, 12:05 PM   #43
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by AWCHIEF View Post
Old boat builders trick for stripped wood screws. Take a wooden match or tooth pick, dip in epoxy, insert in hole, drill small pilot hole, insert screw.
Newer boatbuilder's trick for stripped wood screws. Fill the hole with epoxy, without the toothpick. Insert screw while epoxy is still wet. Allow to dry thoroughly
Not to be used if you anticipate ever having to unscrew it again, because after epoxying the screw in place, the only way to get it out again is to drill it out.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-15-2014, 03:15 PM   #44
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
ill need to take a second look, but I *think* the piece of wood this is screwed into is like a strip of it seperate from the drawer...so I *think* that as such, I could replace that piece of wood if it gets too knarled up quite easily...going to double check tonight...for now going to just try and put in glue, then re-screw in with additional screws and then put in new latches and perhaps that will hold...as long as they dont fling out like that again I think this will work for quite a while....otherwise I could replace that small strip with the same material or even something harder to hold....
Protagonist...new photo I see....I was thinking about you at canopener cause we are the few that use an actual photo of ourself for our avatar....
PharmGeek is offline   Reply With Quote
Old 01-15-2014, 03:51 PM   #45
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Originally Posted by PharmGeek View Post
At dealer I filled both sinks - drained and watched traps and all to look for leaks - dry as a bone back then
Looks like now I just need to put on some plumbers tape around water heater drain plug or replace - someone had recommended I keep a spare one of these and also to try putty on threads
I'm very happy about the water fix though - huge relief
Unrelated to this a couple of the drawers came out during trip back and ripped off a couple of the mechanisms that de-latch the drawer from the rails - screws holding them in into strip of particle board not impressive - drawers still work though - no real damage per se
Part of our get-ready-to-travel routine is to remove the underwear drawers and place them on the floor. One of the kitchen drawers comes open, but has never fallen out, yet. I think that is all a consequence of bad, rough, bumpy, lumpy roads. On the way home from Canopener one of the sink covers came up off the sink and moved across the counter.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 01-15-2014, 04:59 PM   #46
A couple of cup hooks, one above the top drawer, one below the bottom drawer, with a bungee cord stretched between the cup hooks, should do well enough to keep your drawers in place while in transit, and the bungee cord is easily stored out of the way while camping.
WBCCI #1105
TAC LA-4
Old 01-15-2014, 08:17 PM   #47
1988 32' Excella
Robbinsville , New Jersey
...AND I think there may be a 5th low point drain (ill double check this later) for the hot water heater, which has a valve I think in there around behind the hot water heater tank...
The valve by the water heater should be to by-pass the water heater not to drain it, unless they changed something.
Old 01-15-2014, 08:35 PM   #48
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
The reason I say that is that I think there is another small pipe like the one in question in this thread right there so perhaps it's a similar deal
Photo of just below water heater
Name:   ImageUploadedByAirstream Forums1389843311.196837.jpg
Old 01-15-2014, 08:36 PM   #49
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Protagonist - great idea about the hooks !!
Old 01-15-2014, 10:16 PM   #50
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
This is a pic of the arrangement in my '08 27FB. It has the typical 3-valve bypass arrangement and a low point drain seen at the bottom that exits out through the belly via a PVC type pipe. This is in addition to the 2 brass petcocks on the opposite side of the trailer. Click image for larger version
Name:	ImageUploadedByAirstream Forums1389849363.695991.jpg
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 01-16-2014, 04:15 AM   #51
m.hony's Avatar
2013 30' Classic
That may be a high pressure releas?
TAC #MS-10
Airforums #70955
Old 01-16-2014, 07:10 AM   #52
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Maybe? I'm not sure but interested to know....
Old 01-16-2014, 07:13 AM   #53
2008 27' Classic FB
Burkburnett , Texas
No, that's a low point drain for the cold water line feeding the water heater. It's not mentioned in the owners manual, but Jackson Center confirmed it when I called asking what this 4th valve was for. I hadn't discovered the exit pipe until I applied water pressure in the spring when the valve was still open!
AIR 47751
Old 01-16-2014, 07:14 AM   #54
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Ha - same issue I had but different location - seems these manuals need updating!!
Old 01-16-2014, 07:15 AM   #55
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
How can they have a maintenance winterizing section - mention low point drains and miss 2 low point drains in the directions....imagine winterizing by those directions but not draining these two areas....
Old 01-16-2014, 04:35 PM   #56
patentguy's Avatar
2014 30' FB FC Bunk
Pennington , New Jersey
PharmGeek - we had the same thing happen on our maiden voyage with our bunkhouse. Apparently one of the "improvements" with our model year was the drawer mechanism - supposed to self-close. However, I think they need to do some more R&D on the staying closed part. For the amount that we paid for the unit I would expect better. One should not have to use an after market jerry-rigged solution to keeping a drawer closed during transport.
That being said, your damaged drawer should be covered by the warranty.
patentguy is offline   Reply With Quote
