Old 10-21-2011, 10:24 AM   #1
2007 19' International CCD
The Woodlands , Texas
Pex fitting leak - toilet supply line
Hi all...
I have a very tiny leak in my toilet supply line at the right angle fitting just behind my toilet before my shut off valve.
I replaced the toilet flush valve (which also leaked) and when doing created this other leak (may have loosed the crimp).
It kind of a tight space behind the toilet, but can I just re-crimp at the site of the leak?
Thanks in advance!
eberrobw is offline   Reply With Quote
Old 10-21-2011, 05:01 PM   #2
2010 27' FB Classic
N/A , Texas
I'd give it a try. But in case that doesn't work try Sharkbite fittings.
Recently I replaced my toilet and found that the Sharkbite brand fittings are easy to use in tight spots instead of pex. I got mine at Home Depot.
Old 10-21-2011, 05:25 PM   #3
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
X2 for Sharbite fittings. If you have a tight spot to reach or don't have access to crimpers and only have a few connections to make Sharkbit is great. I used them when I changed out my water heater. They made the job much easier.
Ridgerunner3 is offline   Reply With Quote
Old 10-21-2011, 05:33 PM   #4
Thanks, I think I'll give Sharkbite a try.
Old 11-19-2011, 07:36 PM   #5
Goal15's Avatar
Dallas , Texas
hmmm i have the exact same thing.. just started a new thread on this very subject... guess i will have to check out sharkbite
Goal15 is offline   Reply With Quote
Old 11-20-2011, 10:18 AM   #6
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
A word of caution on the sharkbite. The PEX has to be cut clean and square or they will leak. If its a tight place to get at, take extra time to do it right.
Dave
Old 11-20-2011, 10:22 AM   #7
Maniacal Engineer
barts's Avatar
Menlo Park , California
I use one of those cutters made for PVC pipe on PEX - works great, and makes for a clean, square cut. Another thing that can cause leaks is not seating the PEX all the way into the fittings. Avoid short straight runs between fixed points for this reason; it's too hard to flex the PEX properly when it is long enough to go all the way into the fittings.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 04-12-2012, 09:42 PM   #8
Just to close this out, I went with Sharkbite as suggested. It works great especially in the tight space I had.
Thanks all!!!
Old 04-13-2012, 09:50 AM   #9
Splitrock's Avatar
Sioux Falls , South Dakota
Any place hard to get at and for all faucet and fixture connections I use flexible braided stainless steel hose.
Old 04-13-2012, 09:55 AM   #10
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
I got everything I needed, including connections from PEX to various risers, from the Ace hardware store in Taos. Just get to know the folks in the plumbing section: Many are tinkerers themselves and know their product lines well.
Lynn
WBCCI 21043
Toilet Fresh Water Valve Leak perryg114 Sinks, Showers & Toilets 7 10-11-2011 06:41 AM
How do I find the correct replacement toilet? meredith Sinks, Showers & Toilets 1 07-15-2011 12:20 AM
Water supply question at a state park. meadowlm General Repair Forum 6 06-07-2011 10:57 PM
1978 ambassador toilet leak mohrjr Sinks, Showers & Toilets 4 05-20-2011 09:38 PM
Split water supply line Eliminator46 Fresh Water Systems 10 05-03-2011 06:43 AM
