Old 11-17-2010, 05:00 PM   #1
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
PEX and toilet supply line question
I replaced my copper with PEX, but I haven't figured out what I need (connectors and tubing) for the water supply line to the toilet. One thing to note, I am using the Shark Bite brand of connectors on all the PEX. I thought I could use one of these with a braided, flexible tube for the water line, but they don't fit together. I guess then my question is, how do I connect the PEX to the braided line? Or, is there another solution?
adwriter73 is offline   Reply With Quote
Old 11-17-2010, 05:04 PM   #2
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
You need to get yourself some clear plastic hose and white barbed fittings from a plumbing supply. I ran into the same thing myself. I think home depot may carry all the stuff you need. Also grab some metal screw down hose clamps.
ddstech is offline   Reply With Quote
Old 11-17-2010, 05:48 PM   #3
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
You can buy a Shark Bite with a built in shutoff. Connect a standard braided metal line for the toilet to one side and slide the PEX to the other.
Works great I used one last week I bought it at a local hardware store.
Garry
Old 11-17-2010, 06:09 PM   #4
ddstech's Avatar
Folsom , California
That sounds like a better setup then mine. Those fancy shark bite connectors werent available when I did mine. I think they are worth every penny.
Old 11-17-2010, 06:32 PM   #5
lewster's Avatar
Naples, FL , Hood River, OR
Almost every common RV toilet uses a 1/2" FPT or MPT fitting at the water entry (generally MPT). If you are using 1/2" PEX and the associated Shark Bite fittings, then they have one that terminates with a 1/2" MPT thread. The big box stores and ACE Hardware carry braided steel hose with both ends terminating in 1/2" FPT, which will match perfectly. The suggestion of using the Shark Bite shut-off valve is a sound one. Terminate the PEX with this valve, add another short piece with the 1/2" MPT fitting, then the braided SS hose up to the toilet water inlet and you're done!
BTW, FPT = female pipe thread and MPT = male pipe thread.
Old 11-18-2010, 03:19 PM   #6
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
OK, I will try this. What is the reason for the "shut off valve" though versus a similar valve that doesn't have a shut off feature?
Old 11-18-2010, 03:52 PM   #7
garry's Avatar
1969 31' Sovereign
The shut off valve I used eliminates one SB connection.
The steel braided line has 1/2 NPT on one end to toilet and 1/4 that screws onto the SB. "
So you have;
PEX water line......SB shut off......steel braided line......toilet.
Garry
Garry
Old 11-18-2010, 04:13 PM   #8
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Make sure you check the size of the fitting on your toilet. The fitting on the new one I installed was bigger than standard home toilets. Cause me an extra trip to ACE. I added a shut off valve but I was using crimp fittings instead of Shark Bite.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 11-18-2010, 04:57 PM   #9
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I haven't seen a shark bite ball valve with the pex on one end, and threaded on the other (?); only pex-pex...and they were very expensive, as ball-valves run.
I was going to ask about transitioning from the 1/2 lines to the faucets...Sharkbite has tees, but they're like 10 bucks a piece. so I'd want to keep the SB fittings to a minimum. My thought is to use them sparingly, in such a way that sections of plumbing that are difficult to reach can be easily removed when (notice I didn't say "if") something like a pressure regulator or check valve fails. (or, something springs a leak).
Most of my bathroom plumbing is damn-near impossible to access.
anyway, wondering if they make a crimp-style tee that is pex-1/2"mpt-pex.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 11-18-2010, 05:11 PM   #10
lewster's Avatar
Like I said, 1/2" FPT on BOTH SIDES of the steel braided line.
Old 11-18-2010, 06:20 PM   #11
2011 27' FB Flying Cloud
Bradenton and Saluda , Florida & North Carolina
Pictures please! To me, a picture says it all! A lot of what you are describing may as well be Greek
Thanks in advance. Have to correct leaky pex from toilet by either replacing with correct connections, or tightening copper compression fittings.
ncbambi is offline   Reply With Quote
Old 11-20-2010, 09:03 AM   #12
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
thanks for the tip, lewster. it worked. only problem: i must've cross-threaded when when i attached the braided line to the toilet. it's on crooked. i removed it and tried 5 more times. crooked. all times. it screwed all the way on. just crooked. i'm hoping this doesn't mean a leak. have to wait until i finish the the rest of the system to check it.
Old 11-20-2010, 12:16 PM   #13
Weldon Spring , Missouri
Those toilet connections can look crooked, because of your viewing angle......(I've experienced that phenomenon)......if it felt good when it went on you're probably OK.
fmr.capt.evi is offline   Reply With Quote
Old 11-20-2010, 12:23 PM   #14
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Because I am a plumbing idiot tell me this- for 1/2" Pex to the trailer sinks ( 4" spread faucets) you need a 1/2" to ? connector.
To the shower and toilet 1/2" to ? same question.
AND coming in from the outside city water connection ? to 1/2". This will make my life a bit easier when I go the bog box to get pex Sharkbite or similar connectors.
Thanks guys
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Question on toilet supply line ridinatlast Sinks, Showers & Toilets 2 06-27-2010 03:47 PM
LP supply line uwe LP Gas, Piping, Tanks & Regulators 9 06-17-2009 02:49 PM
Pex line and flair-it fittings question Frieberg Plumbing - Systems & Fixtures 3 10-13-2008 07:40 PM
Propane Supply Line? Over59 LP Gas, Piping, Tanks & Regulators 14 02-16-2005 06:50 PM
New LP Supply line? themostbob LP Gas, Piping, Tanks & Regulators 0 05-01-2003 09:35 AM
