Old 01-07-2011, 04:07 PM   #15
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
And dark; the small showers are dark enough already. I'd reconsider - after all, one does not spend any more time than necessary in an Airstream shower. Navy showers and all that.
Now, if you really don't intend to use it and wish to simply make it a decorator item, then....
nah.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 01-07-2011, 07:42 PM   #16
Maniacal Engineer
barts's Avatar
Menlo Park , California
Clear finished wood can be made to work - but I'd use several coats of epoxy (West System or similar) and then polyurethane over that. It's a lot more work, but can look very nice.
Pygmy Kayaks are finished that way....
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 01-08-2011, 11:43 AM   #17
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
Originally Posted by CanoeStream View Post
Long as we're talking boats and rot resistance -- how about hackmatack?
and, they make great "knees" in a boat.
Originally Posted by Bill M. View Post
My suggestion is to just do not do it.... Lousy for repeated wetting and drying. Seems like it will get slimy and moldy.
Bill might also be right with his suggestion. the slimy moldy potential would also have much to do with how often the shower gets used.
for a "daily driver" the wood may be impractical, but for a shower being used occasionally, I am, truthfully, unsure?
in any case, if you're going to press forward on this, you might also consider using teak or honduras mahogany rather than cedar or redwood.
any other "wooden boaters" out there to weigh in on this one?
best,
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 01-08-2011, 12:38 PM   #18
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
I am an old "wooden boater". Teak or mahogany are good choices. But I still believe it has to be sealed/polyurethaned both sides to keep the wood from expanding/contracting. If God wanted fiberglass boats, He would have made fiberglass trees. Sal.
noreen&sal is offline   Reply With Quote
Old 01-08-2011, 12:43 PM   #19
noreen&sal's Avatar
1981 27' Excella II
In 1992 I built a 18 foot cedar strip canoe. Strips were 1/8 x 1 inch. Inside and outside were fiberglassed, sanded, and Polyurethaned. The canoe has sat under a tree in my back yard [in the shade] and is still strong. Sal.
Old 01-08-2011, 03:09 PM   #20
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
We lived on our sailboat for 10 years and used the shower daily. The interior of the boat was teak including the heads and showers. The teak was varnished however the floor grate in the showers was unfinished. We never had a problem. There was one significant difference from an Airstream, ventilation. The boat had dorade boxes with vent scoops that provided ventilation continuously year around. When it got cold you just had to turn up the heater. Without the ventilation the boat was damp and musty.
Airstreams are sealed pretty tight, in spite of the leaks. I don't know that you could get enough continuous ventilation short of running a dehumidifier continuously to make wood of any kind in a shower work. By the way apitong, the wood used on truck and trailer beds holds up to weather but also needs to be ventilated.
Cheers, Dan
Cedar Point Halloweekends Rally DanB Forum Rallies & Meet Ups 2 07-30-2008 06:57 AM
Anyone in Redwood City (CA) to help inspect? Yomster Buyer Guidelines 7 05-30-2008 03:13 PM
Anyone Going to Cedar Key this weekend? Pick On The Road... 3 01-24-2006 06:19 AM
1973 Sovereign Redwood Interior Custom Build Oceancontainer 1970 - 1973 Sovereign 1 04-18-2004 04:06 PM
