Old 01-23-2012, 12:11 AM   #1
1979 30' Argosy
saint augustine , Florida
Thumbs down oh s@*^(# black water holding tank clogged
EMERGENCY !!! the black holding tank valve was left open, and now the tank is plugged with waste. nothing drains out. i attempted to reverse flow water , but only get small particles. what's next ??? the toilet bowl is also now full.
happypill is offline   Reply With Quote
Old 01-23-2012, 04:40 AM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Do you have any kind of a snake or piece of steel cable that you can shove up there and break the jam, Possibly even pushing the running hose up the line if it is all you have available.?
No matter what you do it will be messy.
One more possibility is to put a hose type drain cap on and reverse pressurize it.
You didn't mention whether you are home or on the road.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 01-23-2012, 04:49 AM   #3
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Danger, Will Robinson. That seems like it could go horribly wrong. Maybe good for a scene in the Robin Williams RV movie?
Old 01-23-2012, 04:58 AM   #4
Indian Harbor Beach , Florida
Happy Pill,
If you are in St Augustine and not on the road, call Sanders RV in Alachua (not too far from you) this morning...they will help....nice service dept.
Andi
kidsgone is offline   Reply With Quote
Old 01-23-2012, 04:59 AM   #5
richinny's Avatar
2011 34' Classic
with the cap with the hose fitting you usually just need a short burst of water to dislodge the blockage. scoop the bowl if you need to make room.
Ricky
Old 01-23-2012, 05:41 AM   #6
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
Not supposed to leave it on, but if you did might make a good video
13 Ram 2500 TD
Old 01-23-2012, 07:12 AM   #7
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Photos, we love photos. Don't forget to wear your foul weather gear!
Old 01-23-2012, 07:26 AM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Close the valve and take it for a drive. You may be able to shake it lose. Hopefully there is enough liquid to blend it to where it will flow. You might try holding the toilet valve open and pushing the waste down with a stick to see if there is space for more water.
If you can make more room, don't fill the tank completely, it needs to have room to slosh around and mix.
Good Luck
Old 01-23-2012, 03:52 PM   #9
toastie's Avatar
1955 22' Safari
Great Lake State , .
toastie is offline   Reply With Quote
Old 01-23-2012, 04:18 PM   #10
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Yeah, be very careful with the reverse pressure idea. It will probably work but I would make it my last resort. See above video. The geyser of poo may come out of the toilet or the vent pipe on the roof.
I would obtain a cheap sewer snake and try that first.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 01-23-2012, 04:39 PM   #11
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
If it were me I'd be inclined to call a sewage removal place and have them pump it out...tell them the situation so they will be prepared for what needs to be done. Don't be embarrassed to tell them like it is...I'm sure they have seen everything.
I agree with jdaylrymple...since the toilet is more than full, there is no where for the back wash to go but up the vent pipe or to overflow the toilet bowl... so be careful if that's the approach you take.
Whatever you end up doing, be very careful and dress for the task to protect yourself.
TB & Greg and Abbey Schnauzer
#3954
Old 01-23-2012, 05:08 PM   #12
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
at least last year there was a company in florida called hydro flush that would come and clean out the black tank. did a good job on mine before I serviced the valve.
you must be hooked to a sewer if the valve was left open?
Old 01-23-2012, 06:27 PM   #13
Lumatic's Avatar
1993 34' Excella
Images: 16
I just had a brain fart and thought I was reading a response to this thread and it was not. But apropos:
Remember what they say:
If you love it, release it. If it loves you, it will come back
Black Water Tank Cover Tartimisi Waste Systems, Tanks & Totes 1 11-06-2011 09:08 AM
Black water tank valve flange Safari64 Waste Systems, Tanks & Totes 1 09-22-2011 07:50 AM
Black and Gray water holding tank leak GoodRed Road 1974 - 1979 Ambassador 0 09-19-2011 04:39 PM
New '67 Safari black water tank? losfew Waste Systems, Tanks & Totes 1 09-06-2011 06:19 PM
Unable to dump black water tank before 20 deg. forecast mikeandnora Waste Systems, Tanks & Totes 3 02-04-2011 09:46 AM
