Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 07-13-2010, 08:35 PM   #1
2009 16' DWR
Denver , Colorado
nu2airstream. Shower pan full of water
Our shower pan has water in it and isn't draining. When we starting filling the water tank, the shower faucet was on and now the shower floor pan is full of water and it won't drain. We have open the drain valueson the water tank and sewage tank and it is still full. Help.
A Beck is offline   Reply With Quote
Old 07-13-2010, 09:24 PM   #2
x
XXXX , XXXX
did you open both dump valves? There are 2. One is for the black tank (toilet) and one is for the grey tank (sinks & shower). The black valve is larger than the grey valve.
wasagachris is offline   Reply With Quote
Old 07-13-2010, 09:39 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
When the grey tank fills, the rest goes in the shower. Sounds like your grey tank is full.
Richard
Old 07-14-2010, 12:15 PM   #4
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
The shower drain will push-pull to drain or fill. I think if you push down on your shower drain and let go, the drain will rise up a bit and then drain. This is pooly described, but try it anyway.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
No hot water in the shower Kestrell Sinks, Showers & Toilets 11 05-28-2010 09:46 PM
No hot water in the shower ! LisaP Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-10-2009 06:58 AM
05 Airstream Westfalia 18.5DVD Full Kitchen,Shower&Sink eBay Watch Airstreams on eBay 0 04-18-2009 07:50 PM
shower water valve, water is cold!!! cnsilver Sinks, Showers & Toilets 3 11-02-2008 06:51 AM
Black Water Tank Shows Full When Empty yochanan Waste Systems, Tanks & Totes 12 01-21-2006 10:41 PM
