Old 04-26-2010, 08:52 AM   #1
Chasmorgan's Avatar
1999 23' Safari
No Water Flow from Faucet.
My bath area faucet has no water flow not even a trickle! Neither the water pump or the outside water connection fix the problem. The first thing that comes to mind is a plug of some sort. I did check the screen and it was clean at the tip. Any suggestions to unplug?
Name:	1999 Airstream 019.jpg
Chasmorgan is offline   Reply With Quote
Old 04-26-2010, 09:06 AM   #2
Chasmorgan's Avatar
1999 23' Safari
Forgot to mention shower, kitchen faucet and toilet all have normal flow and pressure.
Old 04-26-2010, 09:16 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Is this a problem on both hot and cold side?
If so I would remove the screen and try it without the screen.
There is a chance the cartridge in the faucet is plugged. Remove the cartridge and inspect it.
If it is problem on only one side then you may have to check the branch line piping leading to that side.
My bet is on the screen.
2004 Excursion 4x4
Old 04-26-2010, 09:17 AM   #4
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Go a little further upstream - behind the screen is a little plastic dohickey (water saver, actually) that has very small holes which are easily clogged by sediments that settle there. Remove it, noting carefully which way it goes back together, and it is a good bet that this is your problem.
Going with the flow,
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 04-26-2010, 09:20 AM   #5
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
You may need a new cartridge,call Moen 800-848-6636,they will send you a new cartridge,I have encountered all kinds of stuff blocking the ports in the cartridge and valve. Dave
easyride is offline   Reply With Quote
Old 04-26-2010, 09:32 AM   #6
Chasmorgan's Avatar
1999 23' Safari
Does not work on either the hot or cold side. I did clean the screen and inspected the dohicky (green plastic with small holes). Where would I find the cartridge? I really appreciate the help!!!!!! Thanks
Old 04-26-2010, 09:36 AM   #7
Ready-to-Travel
pmclemore's Avatar
Try one more easy thing: Leave the dohickey out and try the water. Then the cartridge is the next step. Your big box Lowe's or HD will have the cartridge (or the dohickey, for that matter).
Pat
AIR 3987
TAC VA-2
WBCCI 4596
Old 04-26-2010, 09:51 AM   #8
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
The cartridge is the faucet valve, located under the handle. On the top of the handle is a small cover that will pry off with a pocket knife or small screwdriver. Under the cover you'll find a Phillips screw. Remove the screw, and pull the handle straight off. Now you'll have the cartridge stem exposed. It's held into the faucet with a nut on top of the chrome base. Remove the nut, and then the cartridge will pull out. Replacement is just as easy. Just make sure you note how the old cartridge came out so you can put the new one in with the exact same orientation.
Obviously, make sure the water is off before starting! For that matter, does your trailer have shut-off valves for the hot and cold water under the sink? Some do. May want to check those as well.
Chris
Old 04-26-2010, 10:01 AM   #9
Chasmorgan's Avatar
1999 23' Safari
Thanks Chris!! Hopefully it will be as simple as your instructions!
Old 04-26-2010, 12:46 PM   #10
Chasmorgan's Avatar
1999 23' Safari
Fixed!! It was the little green dohicky! To my eyes the tiny holes looked okay but I spent $2.99 to replace and now the flow is perfect! Thanks for all the help!
Old 04-27-2010, 08:52 AM   #11
Ready-to-Travel
pmclemore's Avatar
We love easy, cheap fixes. Lord knows they are few and far between.
See you on the road - Pat
AIR 3987
TAC VA-2
WBCCI 4596
Water flow stopped suddenly dryan Plumbing - Systems & Fixtures 7 08-25-2008 06:25 AM
Shower Dribbles ... Faucet and Toilet flow great Killo1 Fresh Water Systems 3 03-18-2007 08:54 PM
city water won't flow..help! AirSpleen Fresh Water Systems 9 08-20-2006 05:39 PM
Water flow question... Sneakinup Waste Systems, Tanks & Totes 1 05-19-2004 06:20 PM
No water flow Michael W Plumbing - Systems & Fixtures 4 10-12-2003 08:26 PM
