Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 10-05-2007, 07:13 PM   #1
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
No more Rinse cycle?
I went to use my sprayer for my toilet this evening and all I got was a dribble. I have to admit she does not get used often but I still need it.
I looked at the back of the throne as best I could and can only see where it hooks up.
Any suggestions for my fairly new thetford?
I know she is still under warrenty but I ned to repair it before I can get to a dealer.
Michelle
If you think you are having a bad day go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT)
Daisy, (06 Turbo Diesel F-250 w/Tow Command, the perfect TV)
Butter Cup, (06 Classic 31 w/dinette, solar)
45,000 miles in two years!
http://Michelles-Adventures.US
Old 10-05-2007, 07:19 PM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Michelle,
I can only assume from your post that the toilet flush works ok?
If so, then I'd suggest taking the sprayer off, or apart, to see if it has clogged somehow. Might be as simple as construction debris from when "they" built and plumbed your trailer.
Uwe
Old 10-05-2007, 07:39 PM   #3
thecatsandi
Missoula , Montana
uwe,
It flushes. And the openings in the end of the nozzle are fine. i think . I pull it off and see if water flows out of the hose freely. Did not think of that initially. Long afternoon in the simulator....
Michelle
Sarah
Old 10-05-2007, 07:40 PM   #4
uwe
418
uwe's Avatar
Images: 40
uwe,
Ma'm, put down the wine glass, and get to work....
Uwe
Old 10-05-2007, 07:43 PM   #5
steelbird312
steelbird312's Avatar
Profile:  1989 29' Excella
Griffin , Georgia
Images: 11
Did you say new?
Michelle, I notice you said new- that leads one to wonder about the manufacturing of the new unit. First, I would try to ensure there was not a kink in the hose, or maybe oinched somewhere. The next thing would be to take the sprayer head off the hose, and see if water comes out the hose when you mash the small pedal. If so, then it's the head-either inop or stopped up. If no water comes from the hose, then most likely it will be the valve.
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 10-05-2007, 07:54 PM   #6
thecatsandi
Missoula , Montana
Well. It appears to be the valve. I removed the spray head and the water runs out in a steady stream but without force. I put my finger over then end and it stopped. The spray head is reasonably clean.
Michelle
Sarah
Old 10-06-2007, 09:10 AM   #7
uwe
418
uwe's Avatar
Images: 40
Look here..
You did say Thetford, right?
- RV PARTS OUTLET
These guys have repair parts.
Or, buy a Sealand porcelain toilet. They have a full size toilet seat.
Uwe
Old 02-02-2008, 01:29 PM   #8
thecatsandi
Missoula , Montana
Black tank flush
Just in case you were wondering. Here is what the tank flush looks like from both sides. Do look any further if you get queasy.
Note the sensor at the bottom left. In the second picture the small holes in the nozzle
Don't ask how I got the second picture. I am not going to tell.
ID:	53575  Click image for larger version
Michelle
Sarah
Old 02-02-2008, 01:49 PM   #9
FreshAir
FreshAir's Avatar
Profile:  1966 24' Tradewind
Placerville , California
Okey, I won't ask. But I hope you won't take it too personal if I don't shake/hold your hand.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
Lake San Antonio, 10/07
'Cover Photo'
1966 Trade Wind
455 cid
Old 02-02-2008, 04:33 PM   #10
3Ms75Argosy
3Ms75Argosy's Avatar
Profile:  1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Michelle - uh.. was that a flight simulator, or a black tank simulator.... I don't want to hear about a long day there if it was the latter...
3Ms75Argosy is online now   Reply With Quote
Old 02-02-2008, 04:43 PM   #11
2airishuman
2airishuman's Avatar
Profile:
Originally Posted by FreshAir
...I hope you won't take it too personal if I don't shake/hold your hand. Neil.
i wouldn't worry about shakin' hands...
she's got plenty of chances to wash 'em.
just don't ASK to borrow the little autofocus camera that was IN her hand...
cheers
2air'
and i hope folks can NOW SEE just how flimsy, small, insignificant and useless the factory btf really is...
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Black water rinse clogged! Resorts Waste Systems, Tanks & Totes 4 07-22-2007 10:26 AM
Longer furnace cycle time wacnstac Furnaces, Heaters, Fireplaces & Air Conditioning 18 05-29-2007 02:45 PM
Black Water Rinse Noise James Schmidt Waste Systems, Tanks & Totes 16 05-19-2007 06:49 PM
Which Deep Cycle Battery? boltos Batteries, Univolts, Converters & Inverters 26 12-07-2004 05:57 PM
