05-28-2010, 01:12 PM
2005 28' International CCD
Upland
No hot water in the shower
My wife and I have a 05' 28Ft CCD, and on our last trip while we were drycamping at Jalama Beach in northern Ca we were sorry to discover we could not get any hot water in the shower. All other faucets in the rig worked just fine and when I opened the access panel in the wardrobe next to the shower stall I could feel hot water in the PEX tubing feeding the shower valve. Anyone else have this problem, or any advice on how to solve this chilly problem .
05-28-2010, 01:30 PM
2005 19' Safari
GLENDALE
, AZ
A couple of quick questions:
* Have you previously had hot water in the shower?
* Do you have cold water in the shower?
* Have you recently repaired or replaced something associated the hot water?
05-28-2010, 01:57 PM
Upland
Yes, hot water has been available in the shower before. Although now that I think about it, this may have been the first attempt at a hot shower while dry camping.
Cold water is flowing just fine, as I turn the water valve from the cold area to the hot the water slows and stops, I am assuming as the cold water slows to allow the hot water to mix. Turning back from hot to cold restores water flow.
No, recent repairs or alterations to the water system.
05-28-2010, 02:06 PM
1980 31' Excella II
Springfield
Don't know what faucet you have, but if like mine, a 1980 Excella, it is a Moen faucet. Possible that the cartridge is plugged. Happens often on new construction of homes. Could be plugged on the hot side in the cartridge itself.
Good luck
05-28-2010, 02:13 PM
Upland
Riverrat,
Yup, the faucet is a Moen. You mention a "cartridge", I 've broken the shower side down to the stem. Is that whole valve portion a "cartridge", that can be removed without taking the whole valve assembly out?
05-28-2010, 05:42 PM
Weldon Spring
, Missouri
You probably need a new cartridge (I recently had the same problem). They are available at Lowe's, Home Depot, etc. The new one will come with a special little plastic adapter that will facilitate the removal of the old one. You will not have to remove the whole assembly, thank goodness.
05-28-2010, 06:33 PM
2007 25' International CCD
Ponderay
, Idaho
This happened to us last year and we replaced the cartridge. We were told that sometimes you can soak them in vinegar and they will open up again. Good Luck
Leslie
05-28-2010, 07:17 PM
2006 19' Safari SE
Nawthin'
, Hemisphere
Don't spend a dime....
Moen cartridges are guaranteed for life.
Contact them for a free replacement.
They'll even send you the special tool that you need to remove the old one !
*** KEEP LOOKING UP ***
T & K
05-28-2010, 07:32 PM
1977 27' Overlander
1963 19' Globetrotter
Naples
While you are waiting for Moen to send you one,shut off the water,remove clip,see if the cartridge out if it will come out ,take the cartridge out,take it apart,hold plastic and push brass part out thru the back. Grease all the parts,put it back together,note it says hot & cold on cartridge,have the writing up. Now it should work.
Your valve is so easy to get to ,I would be tempted to throw that Moen away and install a Kohler valve. We have this problem every fall when the snow birds come back,if the Moen valve is not used it freezes up and won`t balance. Dave
05-28-2010, 09:00 PM
2008 25' Safari SS SE
Colleyville
This happen to us with our Moen faucet. It was the cartridge. It was covered under warranty.
In a perfect world, every home would have a dog and every dog would have a home.
05-28-2010, 09:19 PM
Upland
Thanks everyone, as always great advice. Pulled the old valve out and replaced it. We are headed out this weekend so I spent the extra bucks instead of chasing Moen down for a new one. VERY glad I didn't have to remove the whole thing!
05-28-2010, 09:46 PM
Salem
, Oregon
Originally Posted by fmrcaptevil
You probably need a new cartridge. You will not have to remove the whole assembly, thank goodness.
Hi, maybe you will, I did. That is remove the whole valve assembly. My valve fits through a plywood wall and the shower plastic wall. The horse shoe clip is inside of the wall area and cannot be removed with the valve in place. I bought my valve cartridge at Home Depot; For me, it wouldn't be worth it to wait for a new part. [warranty] I have to pull my trailer forward to work on it and put it back when done and I don't want to move it twice for one job.
Note: late post, but may be helpfull for other's with this problem.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
