Old 11-20-2009, 10:31 AM   #15
Brow324's Avatar
2007 27' Safari FB SE
Scurry , Texas
I finally got around to removing the cartridge and cleaning it. Turned out it was silicon lube build up around the cartridge from the factory assembly lubing the o-rings excessivly. I guess sitting unused for a while just caused it to goop up. Just a wipe down of the internal doohickey and reinstall and it's working fine. First time I was following instructions...Next time it will be a 10 min job.
'07 27 FB - H.A.
Brow324 is offline   Reply With Quote
no hot water in shower Susand Sinks, Showers & Toilets 4 04-18-2008 02:27 PM
No shower hot water Resorts Plumbing - Systems & Fixtures 3 07-11-2007 08:16 AM
How Hot Should My Shower Be ? B4WEDI 2005 and newer - Bambi all models 22 02-03-2007 09:51 PM
Ugh! shower leak detected. mcostanzo Sinks, Showers & Toilets 1 10-03-2003 10:33 AM
Only hot water coming out of shower. TBKP's Overlander Plumbing - Systems & Fixtures 6 06-21-2003 02:41 PM
